Question about Kirby Vacuums
The neutral and drive button is broken in half and the vacuum will not come on as if it is not getting any power.
  • 120 Answers
Kirbys have a safety switch on them and you need to make sure both the brush nozzle is on securley, and in some models the bag unit as well, the drive button is supposed to be like that. Also the cord could be the culprit check it for any cracks or breaks.
Posted on Sep 16, 2008
Kirby gen 3 wont go out of drive
cam neutral button worn, contact your local kirby agent for service or kirby.com
Apr 11, 2012 | Kirby Generation 3 Bagged Upright Vacuum
The power to rotate the beater bar only works half the time..it seems to be very positional. In the past I could get it to work, now it just won't turn. Have tried the re-set button . Expensive vaccum...
Is the power nozzle motor itself not working? If it's not, the problem could be the wiring, the switch, the vacuum power switch, the connectors from hose to machine, or the circuit board in the machine.
My best guess would be the connector from hose to vacuum. The vacuum connector are cheaply made and held in place by flimsy plastic.
If the pn motor is running, it's most likely a broken belt. Initially a worn or loose belt would cause intermittent operation of the brush. Replace it and the brush should work.
Depending on the part, your machine may still be covered by warranty. Check your manual or internet for warranty information.
If under warranty, take it to the store your purchased it from for repair or replacement.
Dec 19, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Beater? bar doesn't spin
That means that the belt is broken, stretched or worn. You need to change the belt. You can get replacements here:
Replacement Vacuum Belts
Dec 08, 2009 | Vacuums
My button for the neutral and drive won't work. a metal piece broke off and no i can't switch the transmission
Find an authorized Kirby Dealer in your area and have the part professionally installed. Very complex. Many parts and screws. If no Kirby store, find a Vac store you trust. Or go here http://reviews.ebay.com/REPLACING-OR-REPAIRING-KIRBY-VACUUM-NEUTRAL-DRIVE-PEDAL_W0QQugidZ10000000011180003
Oct 03, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Electrolux vacuum power bar not turning
First thing is to push the circuit breaker button(reset button). If that dosen't work, check the belt. It could be broken.
Jul 10, 2009 | Electrolux Guardian Bagged Canister Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
