Question about Hoover Vacuums
I have a Hoover SteamVac LS (several years old). I turned it on today and heard slight pop and then an off smell, not a burning smell though. Then after a few more minutes of operation, the SteamVac lost power and now it will not work.
  • 120 Answers
You should check the cord for any burnt marks or cuts, especially the plug, if you don't see any thing it is probably a bad motor.
Posted on Sep 16, 2008
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Hoover advance path steamer practically new started smelling like burning now won't turn on
Service Center Locator - Hoover
hoover.com/locator/
The Hoover CompanyFloormate Scrub Cleaners · Steam Cleaners · Stick Vacuums · Carpet Cleaners · Parts & Solutions · Search Parts · Bags · Belts · Filters · Cleaning Solutions.Missing: advancepath
Hoover steamvac repair - YouTube
? 6:16
https://www.youtube.com/watch?v=cyenpuw2XyM
Apr 23, 2014 - Uploaded by BCtruck, rebuild, repair,repurpose
Its ben two years since we had the carpet in the sunroom steamcleaned. It pains me to pay someone else to ...
Nov 07, 2015 | Hoover Vacuums
Burning smell and noise from vacuum
The roller head may be turning, but something could be rubbing and causing the belt to slip slightly. I'd remove the belt and beater bar and look for foreign material that is stuck
Jan 07, 2015 | Sebo ET-1 Powerhead White
Hoover F7458-900 SteamVac The brushes quit
My Hoover F7458-900 was doing the same thing, brushes not turning and since it is about 7 years old and out of warrenty I decided I had nothing to lose so I took it apart after reading all the other posts on this problem. The brushes are actually turned by a turbine motor (no belts involved) that runs off air produced by the vaccum motor of the unit. The air turns a metal spindle that then turns several nylon gears in the turbin the last of which turns the brushes. The nylon gear that engages with the metal spindle was worn down to the point that it was no longer engaging with it and thus not turning.
The only fix for this problem is to buy a new turbin motor which is not that expensive about $34 plus shipping since they don't sell just the nylon gear. Hope this helps
May 23, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Burning smells from the bottom on my SteamVac Widepath LS. How can I open it to check the belt? do you have a diagram? Thanks
that model doesnt have a belt, it has a gearbox that runs the brushes. if you are getting a burning smell its probably the motor going bad. how old is the machine? i can give you a diagram if you want to attempt to replace the motor or would just like to have it. Let me know and ill upload it to my adrive account and give you the link.
Jan 05, 2010 | Hoover STEAMVAC VACUUM Vacuum
Hoover steamvac shooting sparks from motor
the motors shot some times i have fixed them if it hasn't been ran to long let me know im sure i have a motor
Dec 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I was cleaning my carpet using my hoover steamvac ls. I had already changed the water 3 times. The last time, the water ran out and I kept running it for a couple of minutes trying to **** up some of the...
(1) take the tank off and reassemble to assure you sealed to the lower handle.
(2) the water feed has nothing to do with the motor or electrical, purely mechanical.
Hoover web site is free, no cost.
Sep 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Machine wont turn on
Either the motor is fried or the belt is burnt. If you can't hear it turn on, then check for any fuses that could have blown. They will be glass tube type. If fuse is good, motor or power supply could be bad. You can test them with voltmeter.
Sep 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover dual v steamvac make loud noise and sparks
Be careful. This could be a shorted wire inside where the motor is. If there is sparks , something is exposed and touching. The motor also may be ready to give out. Unless your daring enough to open the whole thing up I would bring it to a shop or replace it.
Jul 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
95 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
