Paper does not go into the printer. One corner of a page will go down a bit but not the rest. There is no paper jam or any other difficulty.
  • 148 Answers
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Posted on Sep 16, 2008
Re - Phaser 8200DP Solid wax printer; very often doesn't pick up paper from bottom tray, resulting in 'jam' message. Also, tends to fold the top corner of a two-sided (duplex) print job on exiting after...
Clean the pick up rollers with alcohol. They need to be really grippy.
If it's folding the corner of paper I expect there is a bit of torn paper stuck in it.
Oct 29, 2013 | Xerox Phaser 8200 Laser Printer
Hp photosmart printer keeps saying paper jam
Use a flashlight to examine as much as possible of the papaer path. There may be bits of paper or paper debris lodged in some obscure corner
Sep 29, 2012 | Cisco Photosmart C4780 Wireless AllInOne...
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Printer Jammed
If you unplug the machine when the printhead is out of the corner, you can shine a light in and see where the crumpled paper is, usually on the right side where the cleaning assembly is.
Aug 12, 2009 | Brother MFC-5840CN All-In-One InkJet...
Paper jam dell 924 inkjet printer
Is there a door or access on the back of the printer? Some printers can be accessed there.
Hope this helps. Bud
Jan 12, 2009 | Dell 924 All-in-One InkJet Printer
HL-5140 paper jam
Perhaps look along the paper path for the little bit of paper that maybe stuck along the path somewhere. I had this problem and it was just a little piece of the corner of a page wedged in the back of the toner tray.
Dec 30, 2008 | Brother HL 5140 Laser Printer
Epson c88+
Ther is a obstruction in paper path, something has dropped down where paper goes in, or a fragment corner of a removed paper jam is in paper pathway
Nov 16, 2007 | Epson Stylus C88 InkJet Photo Printer
94 people viewed this question
