Question about Nikon FE 35mm SLR Camera
Film advance lever.
My film advance lever seems to be stuck. everytime i load my film the lever won't budge.
  • Palmbeach
    Palmbeach May 11, 2010
    Does it move without a film in the camera? If not, it should. Secondly, check the spool on the left hnd side that holds the film canister. Make sure it is not stuck or difficult to move.
    Problem Solver:
  • 5 Answers
Make sure its not set on "Auto". Mine did this. After i took it off the "Auto" setting, it would advance.
Posted on Sep 25, 2008
  • 4 Answers
Do you press the shutter button to release the lever for the next photo? That's how you advance the film from the exposure to light, when first insterting the film.
Posted on Sep 19, 2008
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
Everything seems to function well, actually, I've never used this camera. Got if off of ebay, so maybe I was gypped. Anyways, the film advance lever seems to be stuck. It only goes half way. I can put...
If the lever won't advance even when there is no film in the camera, then I would say there is a problem. (p.s. You haven't told us the make and model)
May 29, 2011 | Cameras
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film advance
I removed the advance lever cover as suggested and tightened the screw. This did not solve the issue. However, I then realized the film rewind button on the bottom of the camera was stuck on the "in" position. I could not get it to release which meant I could not advance the film lever to free up the shutter. To solve this issue I removed the bottom cover from the camera (taking out the 3 small screws) and then pulled the advance lever button all the way to the right. This released the button that had been stuck in and allowed me to advance the film lever properly again and take more pictures. Hope this helps!
Jul 14, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Film advance lever
please read the manual... u ll get the solution.
Jun 24, 2008 | Nikon FM10 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Nikon FE 35mm SLR Camera Logo
2,061 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
