Question about Bosch HBN 9163 GB / 9163 GB hot-air Double Oven
Bosch hbn s gb
Hi the fan works in my oven but it wont heat up, what will neen replacing?
  • 99 Answers
Oven element would need model and ENR No. to supply
Posted on Oct 12, 2008
Bosch HBN 91 Sticky Fan
Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Tip
Common heating faults with Bosch HBN 560570B / 560550B single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBN 560570B / 560550B Electric...
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
Bottom oven not working only fan & light works - top oven works fine
The ovens have separate heatin elements. Sounds like your bottom oven element needs replacing
Jun 30, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
I have a Bosch HBN7053GB /05 oven which worked fine apart from the bottom oven does not heat up, the light and fan are both working just no heat. I have replaced the element but still no heat, so now im...
You changed the element does everything else work fine, stovetop elements,broiler etc.if so check your wiring going to the new element and to the switch if they are fine it may just be the temp/control switch
Mar 12, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
I can hear the fan but there is no heat!
If the fan is working o/k, the n you need to fit a new o ven element, located at the rear of the oven compartment behind a removeable cover.
Oct 11, 2010 | Bosch HBN 7052 GB Stainless Steel Electric...
Main oven doesn't heat up. is there a fuse i can change some where?
If it is a electric fan assisted oven, and the fan is working o/k, then you will probably find that the oven element is faulty.
This is located at the rear of the the oven compartment, behind a removeable cover.
Hope this helps.
Dec 31, 2009 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bottom oven does not heat up fan works
The element is usually located at the rear of the oven compartment,behind a removeable cover, this is also where the fan is located.
Hope this helps.
Nov 29, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Bosch double oven, fan and light work but won't heat.
my lower oven wont heat on my HBN 70 got light and fan but no heat
Oct 18, 2009 | Bosch Ovens
Fan working but oven not heating,if it is element how do i replace it. Model number BoschHBN9153GB double oven.
It will be the element that needs to be replaced, remove panel at rear inside of oven, you will see the element located there.
Please rate my solution.
Thanks.
Sep 17, 2009 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bosch HBN 9163 GB / 9163 GB hot-air Double Oven Logo
383 people viewed this question
Top Bosch Ovens Experts
bosch5
Brian Sullivan
Brian Sullivan
Are you a Bosch Oven Expert? Answer questions, earn points and help others
