Question about HP Color LaserJet 2600n Printer
HP laptop doesn't recognize HP Colorjet 2600n
I have a HP dv 9820us that runs Vista Home Premium. I also have a HP ColorJet 2600n. When I plug in the USB to my laptop, the laptop makes the tones that something USB has been plugged in, but does not show it loading printer.
I have downloaded from website the updated drivers.
My wife's computer is a HP dv6823us (Vista Home premuium also) and she plugs in the USB to the printer and she is ready to print!
About 3 weeks ago, I completely recovered the 9820 due to a problem with it not allowing me to load my USB 727 modem from Verizon.
I did have the printer hooked up through a home network and worked great. I do not have the net work anymore!
Thanks!
  • HP Expert
  • 141 Answers
You need to reinstall the printer drivers with the usb unplugged. then when you plug the usb into the pc it should see it and activate the printer (plug and play). having said this make sure you can use other equipment with that particular usb cable as the impedance could be bad with the cable. If you need more details post back and i will be glad to help you. Good luck!
Posted on Sep 20, 2008
I have a problem from hp laser colorjet 47OOn whith code error is 54.15
54.15 PRINTER ERRORDescription There is a problem with the Yellow CPR sensor.Action
  1. Turn the printer off, and turn it on again.
  2. Clean the color registration detection sensor above the black print cartridge if the error does not clear.
  3. If this message persists, contact HP.
Dec 27, 2012 | HP LaserJet 4700 Printer
HP colorjet 2605dn displays ''door open'' error message and light
On the memory controller board (the unit inside the printer which each toner unit makes contact with. If you open the front door and remove each toner,you will see a row of 4 contacts plus 4 leds and 4 receivers, encased in a metal casing/guard), there is a small white actuator, just to the left of the black toner,which is coupled to the scanner shutter lever.
If this is not correctly coupled, it will result in the "door open" message. The white actuator should spring back out towards the front of the printer when you press with a small flat blade srewdriver and release.
I had to remove top cover, rear plate, lhs covern High voltage psu and the memory controller board. I made sure the shutter lever and the actuator were set correctly and reassmbled.
Door open message was resolved.
Oct 06, 2009 | HP Office Equipment & Supplies
Is it easy to replace hp colorjet 2840 fusor?
Here is a link to a short animation showing the changing of the fuser:
HP 2840 Fuser Repl
Jan 20, 2009 | HP LaserJet 2840 Printer
How to get my PC recognize the Panasonic NV-GS15
Solution A: make sure you are using the correct cable for what you are doing (eg USB for webcam and importing photos and Firewire for transferring video footage
most desktops have firewire plug in them but laptops don't usually
to get a firewire plug in a laptop you need a PCMCIA to Firewire Cardbus (ask your local retail store for one or buy one on ebay etc.)
after that put the cardbus in your PCMCIA slot and restart
then go to Windows Movie Maker and press "capture from video device"
hope this helps!
James
Jan 25, 2008 | Panasonic NV-GS15 Mini DV Digital...
Lexmark z25
Use the Vista pre-installed Lexmark Z22-32 ColorJet printer driver. If that does not work, use the Lexmark Z12 ColorJet printer driver, listed below the previous driver.
Aug 19, 2007 | Lexmark JetPrinter Z25 InkJet Color...
HP Color LaserJet 2600n Printer Logo
66 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
