Question about Rode NT1A Professional Microphone
How to fix my rode nt1a
I recently dropped my rode nt1s, the protective casing has come off leaving an exposed diaphagm. There is a red wire that seems like it should be attached, but have pushed it through the hole, and hasnt solved the problem. Do i need to solder the red wire to the metal attachment??
    Problem Solver:
  • 13 Answers
Yes, where you can see it was soldered before.
Posted on Nov 30, 2008
Rode Nt1a Beep Sound
Does the background sound get louder or fainter when you change the mic gain on your mixer? If it depends on your XLR cable, it may be radio interference, and you need to make sure you use top quality shielded cable, and that you're wired "balanced".
Jun 04, 2015 | Rode NT1A Professional Microphone
My Rode NT1a stopped working. I checked preamps
Repair of this mic is not something you can do yourself. This sort of failure is common, and I can repair it.
Sep 20, 2013 | Rode NT1A Professional Microphone
My Rode Nt1A also stopped working. I think its because i took the silica gel bag from the case. Should i always keep the mic inside the case after the usage. and i dont use a pop up filter
Removing the silicone bag and not using a pop shield can lead to condensation on the diaphragm. Place it in a bag of rice for a day to dry out any condensation on the capsule.
It may not be due to condensation though. Make sure your phantom power source is working. If possible attach another mic to the same source to see if it works. Check the contacts on the mic and also check the wire for any erosion or debris. If none of these work, fixing the mic may be beyond DIY repair.
Aug 31, 2011 | Rode NT1A Professional Microphone
Rode NT1A: i got an adapter so i can input it in the mic input the pc says an audio device has been put in but i cant find it anywhere! please help me i also have an Acer Z5710
The reason it is not being picked up by your PC is because the NT1A is a condenser microphone and it requires an audio interface that can supply phantom power (48V) to get it powered up. Without phantom power, the NT1A won't work. You many need to buy an external audio interface that provides phantom power to use the mic. Hope that helps.
Mar 03, 2011 | Rode NT1A Professional Microphone
No sound being picked up when connected, may be as I am using a xlr to usb connection and the power is coming off a laptop , how would I fix this? Thanks
The Rode NT1A requires phantom power of 24-48volts DC. The USB socket on your laptop will only supply 4.5volts.
The solution will be to buy a separate power supply or to connect it to your computer through a mixer that includes a phantom power supply option.
Feb 24, 2011 | Rode NT1A Professional Microphone
When using my new rode NT1A microphone with pro tools i can record perfectly ok and there is a strong signal going in but the recording sounds muffled and 'cheap' on playback. Do you have any idea as to...
Assuming your preamp, cables, or room, aren't at fault, then your NT1-A is suffering from typical component failure and will need service. Even new mics of this type can be at the end of their useful lives, due to the cheap components used.
Feb 08, 2011 | Rode NT1A Professional Microphone
My Rode NT1a is not working, I have checked the phantom power and all cables which are ok.
If it is under warranty, I recommend sending it to Rode for repair. Otherwise, I can service any Rode mic. Condenser Microphone Mod Service
Jan 17, 2011 | Rode NT1A Professional Microphone
Rode NT1A Professional Microphone Logo
982 people viewed this question
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
