Sony VAIO K45 Notebook Logo
Posted on Sep 18, 2011
I can't boot from the Internal, or via an External USB connected \r\noptical drive? Any suggestions? Is a boot via a Flash drive possible on the PCG-K45? Many thanks for any input...
Orestan Palaiokastritsas
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 18, 2011
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
1873
Points
44
Hello, have you tried changing device boot orderfrom BIOS?
you should change device boot order or press the appropriate button (commonly F10) during POST (when laptop starts to initialy work, it writes which button the first 5seconds that it starts to work) and then you will see a box that shows all the availiable devices to try to boot from. All computers and laptops can boot from any internal or usb if these devices work properly and have a proper image to boot from.
  • aguadi Sep 19, 2011
    Thanks for the suggestion, but I had already moved "Optical drive" to the top
    of the "boot order" list. Also there is no "USB" device shown in the "Boot" menu
    of the "Startup" screen! Very annoying to say the least! Thansk again...
  • in some old models there was in Bios, an option that said "try other boot devices yes/no". It seems strange such a new laptop not having boot from usb in boot order.
Can i connect my pc which is acer aspire 4720z to my LCD TV WHICH is LG22LH20R? if so which port/data cable i have to use??
The LCD TV does not have the software installed on it to integrate with the Pen drive. That is why. Pen drives are meant for input and output of data via computers with USB ports. The pieces of software required to make a computer recognize and interact with a Pen drive (or indeed any other external flash, solid state or hard disk drive based external storage devices) are USB and Storage Device Drivers built-into a computer's Operating System. Your TV does not have such drivers installed on it because it does not have an internal Storage Device to interact with external storage devices.
Your notebook can connect to the LCD TVs VGA Port by connecting a VGA Cable from the Port to the Notebooks own VGA Port -> press and hold the Fn key bottom left of the keyboard -> press the Function key at the top of the keyboard bearing the image of two monitors -> release both keys -> use the TV's remote to select Menu -> Input/Source -> PC.
The pc does not detect the usb drive, the usb flashes. But nothing comes up
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Is it possible to fix a notebook that has a message with load needed dlls for kernel. It's for a notebook. I've looked it up and it tells me to put the cd in and restore it. I have a notebook and...
Hi.
Yes it is possible to fix the netbook. All you need to do is reinstall the operating system. You will have to get hold of an external DVD/CD drive or install Windows through a USB drive.
With a DVD/CD drive all you need is the XP installation CD. Connect the drive to the power outlet and then plug the USB lead to the computer. turn the netbook on and hit the F12 key or the key it tells you for "Boot Options". Select the "USB CD-ROM" device and follow the on-screen instructions to reinstall the operating system.
If you haven't got an XP installation CD then you'll have to purchase one.
You can also install XP from a USB flash drive. Click on the link I have provided below for an in-depth explanation for how to install Windows XP from a USB flash drive>>>
http://komku.blogspot.com/2008/11/install-windows-xp-using-usb-flash-disk.html
If you decide to install using the USB flash drive then to get the system to boot from the USB flash drive just follow the same instructions for the DVD/CD drive.
Hope this helps and please post back if there is anything else.
Regards.
1helpful
2answers
I cannot find if it's possible to boot from USB for a Dell Dimension 1100. I am trying to restore a computer and the CD Drive has failed, so my primary objective is to load Linux via USB so I don't have to...
if you go to dells website and flash your bios with the most recent version it should give you the usb option and make sure your usb stick has been format to become a bootable drive
2helpful
The screen says: "Intel UNDI , PXE-2.1 (buld 082) For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080225) CLIENT MAC ADDR: 00 03 0D A0 C7 C7 GUID:...
Your computer tries to "boot" from various devices:
* internal disk-drive
* internal CD/DVD drive
* internal 3.5" drive
* external USB device (memory stick, external CD drive, et cetera)
* via your network-adapter -- trying to connect to a "boot-server"
So, restart your computer, and enter BIOS SETUP mode.
Be sure that the disk-drive *IS* listed.
If you want, exclude the "network" boot-device,
since the error-messages that you are seeing are indicating that *NO* boot-server exists on your network.
What the messages *COULD* imply is that there is no media in the CD/DVD drive,
no media in the 3.5" drive, nothing "bootable" connected via a USB port,
*AND* that your computer *TRIED* but *FAILED* to boot from your disk-drive.
That is, your disk-drive either is electrically disconnected (no power reaching it)
or electronically disconnected (the "data" cable is not attached)
or that the disk-drive itself is "dead".
Take your computer to a qualified technician for trouble-shooting.
You may have to replace the "dead" disk-drive with a brand-new one.
2helpful
Hp mini 1116nr won't boot at all - tried booting from flash drive get disk i/o error - what to do
Repair the OS using external cd/dvd drive connect ted via USB, Change boot order to usb drive on the first boot priority.Follow the instruction
Good luck
2answers
My toshiba lap top starts up as normal then the msg media test faiure and no bootable device whats wrong
The laptop isn't seeing the hard drive. It has either bounced loose (doubtful) or the hard drive is defective. You can open panels on laptop and find the hard drive, remove and then replace it and see if it reads. Failing this check to see if it's still on warranty or buy another one similar to yours.
Hoow do you open gateway MX6440. No audio. Bootup
Typically, a computer tries to "boot" from several devices:
1. 3.5-inch diskette
2. internal CD-ROM
3. internal disk-drive
4. USB memory-stick
5. network (if a "boot-server" can be found on the network)
6. external diskette
7. external CD-ROM
8. external disk-drive
So, in your case, either
* the "boot-order" _EXCLUDES_ your disk-drive,
* your disk-drive is not connected,
* your disk-drive is connected, but is "dead" (not responding)
Not being able to boot from the disk-drive, your computer probes, via the network, for a "boot-server". Finding none, your computer reports, in a strange way, that "network cable is not connected to a boot-server".
So, the "check cable" means that the Ethernet cable between the network-port on your computer and the boot-server may be "unconnected".
What this could mean is that your disk-drive is "dead".
Take the computer to a qualified technician, for more trouble-shooting.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
