Question about Epson LQ 570+ Matrix Printer
Pause light blinking, machine beeping, no printing
The pause light is blinking, the machine is beeping; I have turned it off and held down the font and condensed buttons and turned the machine back on, that allowed me to print one label. There are lots of lables in the machine - I use this printer every day for mailing letters. Now we are back to square one. No printing at all, just beeping and blinking!
    Scholar:
  • 147 Answers
Probably needs a good cleaning - with a vaccuum and some compressed air.
Dot matrix (impact) printers usually have a couple of optical sensors - disks with holes in them - to let the printer know where the head is, how fast it's moving, if it jams, etc.
If there is too much dust, dirt, or bits of paper interfering with the beam of light passing through the rotating disks, most printers will stop and indicate some sort of error, rather than force the motor - which may damage the plastic teeth on the gears.
Posted on Sep 16, 2008
How do i cahnge the font type and size of epson lx300+
To change font in Epson LX-300+ Printer is as follows :
Step 1
Switch on the Printer.
Step 2
Hold the Pause Button for 3 Seconds (until you here a beeb sound).
Step 3
Now you see the pause LED blinks, now you press Font button to change the font (you here beeb sound on change of each font).
Step 4
After selecting the font press pause button once.
Step 5
Thats it now your font has been changed.
May 08, 2014 | Epson LX-300 Matrix Printer
Ltf2140
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 29, 2012 | Frigidaire GLTF2940ES Front Load Washer
The dryer just stopped and now wont turn on
WAIT 5 SECONDS.
Jul 28, 2012 | Frigidaire GLET1031FS Top Load Stacked...
Wont start
First you have to find the error code.
So! To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Dec 03, 2011 | Frigidaire Affinity ATF7000E Front Load...
How can i change font in epsonlx-300-II printer
Here is how:
1. Printer should be turned on, but not printing
2. Hold down PAUSE button for 3 seconds. The pause light will flash and the 2 tear off (FONT) lights shows the current font selected
3. Press Tear off(FONT) button to cycle thru fonts till light indicate the font you want. When you select the font needed it stays in use as default till you change it.
Note: Some software can change the printer font selected.
If need more information about your printer check the manual
Jul 31, 2010 | Epson LX-300+II Matrix Printer
How to change boud rate from 19200 to 9600
Here are the complete steps to change your LX-300 bit rate to 9600.
1) Load a paper with the friction lever up.
2) Hold the FONT button and switch on the printer. The printer must sense the loaded paper and must start printing some stuff. If not it rolls and tries to load the paper. In such case insert the paper again and press PAUSE button. Now the printer will print the stuff i.e) the current printer settings.
3) After the printing finishes (the print matter will be around 25% of a 11inch page length), press LF/FF. You will find the current settings. Check the current bit rate which is indicated in the 10th line of the current settings table.
4) Now press LF/FF which takes you to the Table B.
5) Now you are in table B and the lights 1, 2 and pause must be Blinking, Off, Off conditions respectively.
6) Now press the FONT button 9 times. After pressing FONT nine times, Light 1 = Blinking : Light 2 : Blinking : Pause light : ON.
This means that you are in Bit rate menu now.
7) Press PAUSE button.
8) Note down this order of bit rate and the status of 1, 2 and Pause lights.
--300 = ON-OFF-OFF
--600 = OFF-ON-OFF
--1200 = ON-ON-OFF
--2400 = OFF-OFF-ON
--4800 = ON-OFF-ON
--9600 = OFF-ON-ON
--19200 = ON-ON-ON
From the current bit rate you are in now, press the FONT button a particular number of times accordingly.
Suppose you are in 1200 bit rate currently, the lights status will be ON-ON-OFF. If you want to set to 9600 you have to press FONT button 3 times and the lights status change to OFF-ON-ON , which indicates 9600 bit rate.
9) Now, press PAUSE button so that the settings get saved.
10) Switch off the printer and turn it back on after 20 seconds.
11) Switch it off again, Hold the FONT button and switch it in again.
12) After printing finishes, press LF/FF and check the bit rate in the current settings that is printed.
You can have the user manual for your reference.
files.support.epson.com/pdf/lx300_/lx300_u1.pdf
Thats' it. You're done!
regards,
Sabharish
Sep 30, 2009 | Epson LX-300 Matrix Printer
Font
To change font in Epson lx300+ printer,
1. Switch on the Printer,
2. Hold the Pause Button for 3 Seconds (until you here a beeb sound)
3. Now you see the pause LED blinks, now you press Font button to change the font (you here beeb sound on change of each font).
4. After selecting the font press pause button once.
5. Thats it now your font has been changed.
Mar 16, 2008 | Epson LX-300 Matrix Printer
Epson LQ 570+ Matrix Printer Logo
692 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
