I am no longer able to fully view PS3 connected to plasma tv via Component Video Cable. I replaced the cable and reset the system, however this did not solve the problem.
This might solve your problem. when you turn your PS3 on, keep your finger on the front on switch. It should go beep. It was some thing I found out when I changed my normal cable over to a HDMI cable.
Hope this works. :)
Posted on Sep 17, 2008
Ressetig the ps3 on a new tv
Sounds like the Tv your using is faulty. Its could have hardware failure. You did say it PS3 was working on hdmi on a plasma. If your using the default hdmi cable that came with ps3 that also can be faulty. I have always had problems with the default hdmi so i bought a new one that was not SONY and it works beautifully. Another thing the black screen with green is a video cable or graphics issue.
Does this tv work if there is no ps3 connected? if so i recommend using the standard PS3 Component AV Cable. see if that will let you reset your ps3.
Jun 24, 2014 | Sony Playstation 3 (PS3) Console
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Connect ps3 to a non HD tv and picture only black and white?
Are you connecting it to a new SD tv after having been connected to an HD set? You can force the system to reset the video resolution settings by pressing and holding the On/Off button after the system has already turned on. I believe it is ~5-10sec. You will hear another beep after the initial startup beep. This will reset video setting to default and go through the resolution setup wizard again.
However, it is also possible that you are trying to connect a component cable to a composite tv. They are VERY different signals even though the cables fit interchangeably. If you use the Green component cable for video on a composite tv you will only see a grayscale image of the picture. This is most likely your issue. If this is the case you will need to buy a composite cable for the PS3 (the PS2 one is the exact same as the PS3 one.)
FYI Component cable has Red, Green, & Blue cables. Composite has Yellow (Video), White (Left Audio), Red (Right Audio). Both are normal RCA type plugs and will fit in each others plugs, but the signals are VERY different.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
How to connect a humax foxsat-hd to a panasonic dmr 75eb recorder,to a panasonic th42px60b plasma tv,also will i get better result using component cable instead of scart lead. please can you...
You plug the humax into the panasonic dvd recorder and then from the outputs of the dvd recorder plug it into the panasonic plasma inputs
Is component video better than RGB? Well, yes and no, RGB provides the widest bandwidth and is the best choice for connecting audio visual devices like a Freeview box, digibox or Sky+ box to your TV, home cinema or home theatre system. DVD is however different, to reduce the amount of storage required DVDs are recorded using component video, it is therefore better to connect a DVD player via a component video cable to your TV, plasma or LCD TV etc.
Thanks if you have any questions please do not hesitate to ask
Dec 02, 2008 | Televison & Video
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
PS3 HDMI PROBLEM WITH SOUND
I am pretty sure you need to have an Optical cable running from Your PS3 to your sound system...if you have one...
So basically you will have a HDMI cable running from your PS3 into your TV, another HDMI cable running from your TV into your sound system, then an optical cable running from the PS3 to the Sound system. I sadly own a HDDVD sound system but the optical cable tells it to accept the Blu Ray content.....
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
