Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washing Machine
On the normal cycle setting once the cycle completes there is water remaining in the tub. If we run the short cycle, spin and drain, all the water is suctioned out. Not sure why the water doesn't completely drain from the normal cycle.
  • 5,911 Answers
Check your drain pump, or drain line for obstructions. The number one cause of insufficient drainage in this model washer is debris building up inside the clean out trap on the drain pump. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Make sure you check all the drain lines as well. Another common thing that can cause slow drain issues are small articles of clothing getting caught in the drain hose that is attached to the bottom of the wash tub to the inlet side of the pump. It has happened to me on occasion to find socks, underwear and wash cloths lodged in this area. You can usually squeeze the hose to determine if there is anything blocking it. NOTE: In some models, there is a ball valve in the upper most portion of this drain line where it attaches to the wash tub. This is supposed to be there.
If anything has been lodged in the pump impeller for significant periods of time, this can potentially cause damage to the impeller and/or motor. This will affect pump performance. If clearing the pump and verifying that there are no clogs does not fix your problem, more than likely you have a drain pump that is beginning to fail.
If you find that you need to replace the pump, a replacement can be ordered on line at searspartsdirect.com. Just type in your complete model number and look for item number 10 (part #8181684) under the "Pump and Motor Parts" heading. The next link explains how to replace the pump (if required):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 16, 2008
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
I have the 9150pw4. Is it normal for water to stay in the discharge pipe at the pump when the wash cycle is over? Or should all lines be empty?
Yes it is normal for some water to remain in the drain hose. As the pump drains all the water out of the machine and begins to draw air, the water that cleared the pump will not have anything behind it to push it out. You should not have any water remaining inside wash tub however.
Hope this helps you!
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9250MTO does not spin all the water out of clothin
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool duet washer ghw9150pw0 not draining water
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question******
Aug 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Random filling of the tub, door open, leaks on floor.
The only thing that can admit water with the power off to the machine is a bad Fill valve. Replace
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gentle cycle did not complete leaving water standing in the tub.
Whirlpool downloader washer model number GHW9150PWO
PROBLEM Gentle cycle did not complete leaving water standing in the tub
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Normal- the machine does not know if it's in there or not. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Odor
It is normal for the washer to hold some residual water in the wash tub under the basket and in the drain lines. Because of this situation, it is also common for front loaders to smell mildewy. You may have to clean out the drain trap on the drain pump and/or the drain lines. But first, have you attempted to run a "cleaning" cycle on the washer? It is recommended that if you do not normally use hot water cycles that you run a cleaning cycle on the washer about once per week. Place the washer on the hottest setting you have and pour about a 1/2 cup of bleach through the dispenser into the wash tub. Allow the washer to run with no clothes like this until the cycle is completed. This will help in disinfecting the wash tub basin under the basket, the drain pump and drain lines. It is also recommended that when the washer is not in use that you leave the door slightly ajar to allow the wash tub to air out. I own a front loader and have never had a problem in the 7 years that I have owned it by following these simple steps. On newer models of the Duet and Kenmore Elite, there is now a "cleaning cycle" function on the timer to accommodate this feature. Now...if you try these steps and you still have an odor problem, try checking the drain trap for foreign objects. To access the drain trap you will need to remove the lower panel under the door. There are three 7mm screws holding it in place under the bottom edge. Once the panel is removed, the drain pump is located under the tub in the front-center of the washer. There is a screw off cap that you can remove for cleaning. It is recommended that you drain the residual water from the tub and drain lines BEFORE you remove the drain pump cap or you will have about a gallon of water to mop up. You can pull all the water from the washer by taking the drain line out of the standpipe and using a shop vac to drain the water. If you don't want a big mess to clean up this is a great time saver. I hope you find this information helpful. Post back with comments if you have any further questions/concerns.
Jan 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin out
Is the machine draining the water out? The machine will not spin unless the water is pumped out.
Oct 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal De
