Question about Compaq Computers & Internet
My young son has a compaq 6720s. I don't know what he has done but it comes up "bootmgr is missing". I don't have a recovery disk for it. What's the nbest thinh I can do to fix it?
  • 3 Answers
BOOTMGR is missing. Press Ctrl+Alt+Del to restart" message, in menacing white font on black screen. So you hit Ctrl+Alt+Del only to get the same message again, and again, and again, in an infinite, terrible loop. You clutch your chest and rock back and forth and froth at the mouth for awhile. Then you straighten up, take a deep breath, and grab the Vista installation DVD.
See, if your PC's boot disk got bumped out of wack, you can often fix it right back up using the original Vista installation disk, which comes with a pretty extensive System Recovery Tool that's got lots of options (see screengrab). Set your computer to boot from DVD (using the Boot setting in the BIOS), insert the disc and restart. Vista will prompt you for language and keyboard layout options, then ask if you want to reinstall Vista or repair your installation. You want Repair. From there Vista's System Recovery Tool will take over, and lead you down the road to happy vistages again.
If that fails? Try the free GParted CD
Posted on Sep 16, 2008
Compaq Preario CQ56-115DX Notebook wont restart
If your bootmgr is missing and you have windows 7 you should have a repair partition that can be booted into using the F8 key when powering on your machine. If not, you will need a repair/recovery/installation disc to boot from
Mar 23, 2013 | Computers & Internet
BOOTMGR is missing
This may be due to the reason that your Compaq model is only Vista or Win7 Compatible.I didn't get your question properly but as you're having no windows or DOS in your machine.All you need is a Bootable Windows Disc and a working DVD rom to get this done.Cause commands or anything else will require that and even if you fix it with some tricks. Some Other file missing message may appear. But if you just want to push yourself. Normally are Booting files are in the root folder in my case it's in C:\ like NTLDR BOOT.ini BootSect.dos so try to access your root drive.
Dec 30, 2011 | HP Compaq nc6220 Notebook
Where can i get recover disk for my laptop i have a compak it said bootmgr is missing where can i get one or how you burn one on other laptop acer
@ cherylschlei
Compaq laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default. The hotkey for the recovery is the F10 key. After you press the power button, you need to simultaneously press the F10 key to start system recovery. If this one won't work for you, you need to order the recovery discs from Compaq at 1- 800-652-6672. If you're still under warranty, they'll give it to you for free.
Cheers
Sep 03, 2011 | Computers & Internet
Hi my name i would like to no how to fix a lap top i have one that the bootmgr is missing can you tell me if i can download a disk i don't have the money to get it .
You need a Windows install disk , not a recovery one , then follow this
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
If you can't borrow a disk from someone then just find it online; there a dozens of torrents with them out there - for legal reasons i can't give you a link.
Aug 30, 2011 | Compaq Computers & Internet
I have a laptop HP Compaq 6720s and now I get the following code t.w. 0x4001001300001002 and when I will restarted the computer the message boot.mgr missing. What must I do?
That error means that the Boot Manager is Missing. This is usualy caused by either a failed hard drive, or a failed attempt at recovery. If you try to do a recovery and then suddenly halt the process, weather on purpose or due to somthing like power failure, then the first bit of the Recovery boot process, the BTMNGR, can be hosed. If this happens then your only option is to order recovery disks from the manufacturer and install the OS that way.
You might boot into bios (F10 on startup) and do a hard drive self test first to make sure you dont have a hard drive problem...
May 31, 2011 | HP Compaq 6720s Notebook
Does a Hp 6720s laptop with XP pro have a built in recovery feature without a disk.
Hello, Most newer laptops now come without a recovery disk because the recovery is usually on the hard disk partition D.If you check yours and it has the partition for recovery, you can still burn this partition into a DVD media because the partition are usually large, incase something happens to your laptop recovery, you still have your recovery on your DVD MEDIA. Go to start>computer and check. Regards
Nov 25, 2010 | HP Hewlett Packard Compaq 6720s Laptop...
Wont boot up
If you have a windows vista disk handy this is how you repair this.
Boot from the Windows Disk
Select your language > Next
In the lower left hand side click
Repair your computer.
If you do no have a Windows Vista Disk you will need a computer with a working CD burner to download and burn a Windows Vista Recovery disk with. You can find one for your computer here:
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
Feb 04, 2010 | HP Compaq 6720s PC Notebook
Hello the f11 recovery doesnt work instantly goes to BOOTMGR is missing , wat else can i do ?
Did you (or somebody else) re-install Windows on your computer?
If so, you (or they) may have wiped-out the "recovery partition".
Since you have a COMPAQ, contact them, and order a replacement set of "System Recovery" CD-ROMs. Re-install Windows (which will reinstate the "recovery" partition) from those disks.
Oct 28, 2009 | Compaq Presario CQ60-220US PC Laptop
Bootmgr is missing
hi
u use HP Compaq Presario C304NR in this notebook there is one built in recovery partition
when u get boot it display press F12(or any Function key) for recovery press this & follow the instruction
Warning: in this process All data will be lost there is no any option to get it with your data
if this information is useful for u please rate me......
Jun 11, 2008 | HP Compaq Presario C304NR Notebook
Vista with bootmgr is missing message
put your recovery disk or vista OS disk and repair the boot...
Mar 25, 2008 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
126 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
