Question about GE Washing Machines
How do i get into the washing cabinet of my GE Wbse3120b?
  • 1 more comment
  • RoxanC Sep 17, 2008
    Worked like a charm. Thank you.
    Thank you!
  • Anonymous Dec 12, 2008
    Machine won't spin and the belt not broke. What could be the problem?
  • 943 Answers
Hi thanks for the question at the front at each corner about 3 inches from the corner where top meets front with a flat screwdriver insert screw driver and pry up on each corner this will remove front panel pump is on the right to drain manually so you can take hoses off without flooding room put hose in bucket on floor it will drain thanks the appliance doc
Posted on Sep 16, 2008
Installed new control asm on ge washer wbse3120b now all the lights are flashing and no power?
On you old control there was a plug with just a jumper wire. This is the model select plug. Without this plug the washer does not "know" what model it is on and the lights will flash.
Sep 13, 2010 | GE WBSE3120B Top Load Washer
I can't figure out how to open it to fix the basin it fell off the frame and I am trying to put it back on. I have had this problem before and fixed but cannot remember how to get it open
There are two spring clips, one each in line with the left and right edge of the lid, where the top meets the front of the cabinet. Insert a putty knife at these points and push in to release the clips. Lift the panel from the bottom clips.
May 02, 2010 | GE WBSE3120B Top Load Washer
GE WBSE3120B toploader washer leaks only during agitation when super load selected. Is it the pressure switch for water fill level or another possible leak?
knowing this is the only time it leaks helps
sounds like your suffering from suds leak
try cutting way back on your soap 1 tablespoon per load that should take care of your issue
Oct 04, 2009 | GE WBSE3120B Top Load Washer
GE top loader washer water keeps running will only cut off at faucets"
If disconnecting power does not stop the water fill, replace the washer's inlet water valve. It is the part the fill hoses screw onto on the back of the machine.
May 20, 2009 | GE WBSE3120B Top Load Washer
Removing front panel of a ge washing machine
You have to be missing a screw head there somewhere that is still holding out.
May 10, 2009 | GE WBSE3120B Top Load Washer
GE Washer Motor over amp?
If that's the only thing wrong with it, then go to
They are about the most reasonable priced place I have found.
Dec 24, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
109 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
