Question about E-Machines eMachines Desktop PC
My emachine fan stopped spinning along with a number of other problems such as no power to the board, etc... PLEASE HELP!!
  • redz38
    redz38 Sep 17, 2008
    I changed the psu and replaced the heat sync unit and everything turned out fine. Big help!!
  • 3 Answers
Change the PSU!
Posted on Sep 16, 2008
Diagram emachine wiring
There is no specific wiring for eMachine. your wiring goes from power supply (big box with fan) to motherboard (large board with many components) to hard drive, cd rom, fan, etc. pretty easy to figure out if you look closely
Jun 25, 2013 | eMachines T5274 Desktop PC
I cannot start my eMachine ET181003r. Every time I try to start, just hear humming sound for one second and then stop. I am not sure it is the FAN problem or not.
What you are most likely hearing is either one of the fans within the computer case, or a Hard drive. The problem could be many things and would most likely need to be inspected in person. I am sorry I cannot be of more help in this situation. Good luck!
Dec 23, 2010 | eMachines ET181003R PC Desktop
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Emachines t2899 will come on and fans run but screen is still blank
Actually, the monitor is fine. The problem is that the computer isn't booting. The power comes on and the fans spin, but the system board isn't starting. Try reseating the memory modules in their sockets and clearing the CMOS memory using the jumper on the system board. If the problem continues, try another power supply. Finally you may need to replace the system board.
May 13, 2009 | E-Machines T2899 PC Desktop
Emachine T2885 won't start up after I cleaned it with vacuum
unplug and remove the ram and battery remove the jumper on the clear mos for 5minutes Put everything back together make sure everything is seated firmly
Apr 12, 2009 | Intel Motherboard
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
Emachine T3828 power switch connection to motherboard
The "Ultra Helpful Instructions" that Emachines provide (here: http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf) state that when replacing the system board, "18. Attach all cables to new system board", but fails to say where that would be for each cable.
The site below says it's a genuine Intel board in there, so, congrats on that. http://www.e4allupgraders.info/dir1/motherboards/socket478/D845GVSR.shtml
And with that, the link to the manual:
ftp://download.intel.com/support/motherboards/desktop/D845GVSR/SR_English.pdf
You're looking for the info on page 32, I believe.
See if that fixes it up. If not, post back.
Jan 03, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Emachine desktop
I understand that your cpu is not turning on and the repairer confirmed that it is the issue with the mother board. I suggest you to please check the smps fan spinning or not. If its spinning then then the issue could be with the mother board. If not try changing the power cables.
Next check whether your cd rom light is glowing. Even if there is an issue with the mother board, as the power is supplied by the smps the light  should glow if the light is not glowing its clear that something must be wrong with smps.
Please provide us the result of the above steps so that I could assist you further.
Nov 08, 2007 | E-Machines eMachines Desktop PC
E machines h 5038
I had found one continuous problem with the E machine. The CPU fan. Take the cover off. Turn on the system. Is the cpu fan running or very noisey???. I find that the fan as most others collect a lot of dust. You will have to either vacumn or blow the dust & dirt out to free the fan so it spins normally. If the fan has stopped or stops and starts, replace it that may be the reason for the freeze up due to the cpu chip becoming overheated. Now if you are talking about the other fan. The power supply fan stopping and starting the system would shut down when that happens. That would be another issue.
Oct 24, 2007 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
