Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Bag light stays on, powers on then shuts off immediately. What is the problem?
Vacuum powers on then shuts off immediately. The bag light stays on. What could be the problem?
  • 120 Answers
First check to make sure there is a bag in the machine, if so make sure that its in securely, there is a pin switch in the bag door that wont allow the machine to turn on if there is no bag in it. If that's okay, then find the knob on the top of the machine ( in the middle of the canister ) and make sure its turned to the maximum, that is a sensitivity knob that can keep the machine from working ( in case it was clogged, but if its too sensitive it could think the machine is clogged when it really isn't ).
Posted on Sep 16, 2008
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Why does my Vacuum shut off!
Has this happened numerous times? If so, and the filters (all filters) are thoroughly cleaned then its possible the thermal protection circuit could be worn out in the motor. If not, it could be an assortment of other issues. Could you please provide more info?
Jun 17, 2014 | Panasonic MC-V7312 Bagged Upright Vacuum
We changed to a new bag and changed the filter but everytime we turn it on it goes off and the green light turns red.
Try this. Detach hose from canister. Turn on. What happens?
If it runs, place hand directly over intake port. What happens?
If it shut off immediately, an internal part is broken and needs to be replaced. This is a repair that needs to be done at an authorized Aerus, new name for the Electrolux company that made these vacuums, service center.
It's also a problem that's seen a lot when generic "made to fit" bags are used. Genuine bags are made by Home Solutions and will have their name on it. Use of generic bags also voids the warranty. Which, depending on date of purchase, yours may still have on the canister itself with it's components.
Wiring and switch problems can also cause this, so the machine, including hose, wands, and power nozzle, should be taken to a service center for a complete check.
Sep 22, 2010 | Electrolux Guardian Bagged Canister Vacuum
Vacuum turns on for 2 sec and then shuts down, full bag light on , but bag is new
This is more than likely due to a broken control valve assembly. I'm seeing quite a few machines come in for replacement of this part.
To be sure, disconnect the hose and turn on the machine. If it still shuts off immediately, or if you place your hand over the opening and it shuts off, it's due to a bad cva. If it continues running, then the problem is more likely due to a clog in the hose or the tube in the power nozzle.
Also, try replacing or removing the afterfilter and see if that makes a difference.
Sep 18, 2010 | Electrolux Epic 6500 Vacuum
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum will not stay on, new bag in place and power to machine.
It sounds like you have a bad control valve. Take it to you nearest Aerus (formerly Electrolux) dealer and have them change it for you. It shouldn't be too expensive. Good Luck!!
Jan 02, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Aerus lux 5500
Check & replace any filters that are fitted to machine.
Replace bag with new,
Clear hose of any foriegn items & check floor tool for blockages.
Dec 18, 2007 | Electrolux Lux 5500 Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
984 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
