Question about Sharp AR-5316 Advanced Digital Imager Copier
REPLACING THE TONER
HI, I BOUGHT A NEW TONER FOR MY SHARP COPIER AR5316E AND WHEN I INSERTED IT,IT WAS SHOWING AN ERROR CODE F2 OR 2F. PLZ I WILL BE VERY GLAD IF MY REQUEST FOR A SOLUTION WILL BE TREATED URGENTLY. THANKS
  • ifeanyi63 Sep 16, 2008
    i just got to know of this site and will be glad if i will not be disappointed.
  • ifeanyi63 Sep 17, 2008
    some one just gave me a code to reset the copier with and it worked. It's *,interrupt,ca,interrupt,88,ok,1,ok. Thanks guys.
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Posted on Oct 09, 2008
  • 141 Answers
Make sure to pull all the seals off the toner. reseat the toner, try turning the machine off for 5 minutes to reset.
Posted on Sep 17, 2008
  • steve shroder Sep 17, 2008
    thanks for the feedback and the rating
  • ICEMAN Mar 04, 2013
    Take a look at your developer, its less than the usual amount.
    Problem Solver:
  • 7 Answers
Posted on Mar 04, 2013
SHARP AR5316 ERROR CODE F2
1- replace the toner cartridge.
2- replace the chip toner cartridge.
3- check and fix connection between toner cartridge and mcu pwb.
Jul 27, 2012 | Sharp AR-5316 Advanced Digital Imager...
My copier machine sharp AR5316E shows error message 2U, please what is the solution?
remove the catridge to the machine and then insert it back. if it still display the same information the catridge might be damaged need to be replaced.
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error f2 in sharp copier AR5316E
F2 sub code 00 - Toner Sensor problem, ID pattern reading error. You may have to replace the drum unit or have a tech clean the toner sensor
Mar 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar5316e show f2 04 solve this
clear the memory of the machine, change the destination of the toner or fixe in a new toner crum or also known as toner sensor
Jul 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR5316E error code h2
hi in put # + inroput + c + intrupt + 14 + start
Mar 07, 2009 | Sharp AR-5320 Black and White Copier
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
455 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
