Question about Sharp AL 1631 Copier
Red light when you turn the copier on, a red light in the shape of a cylinder lights up. Does that mean the copier needs a new drum? The light is located next to the "three dots that form a triangle" light which I think means you need new toner.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
The triangle dots are "need toner"
the cylinder is "need new drum"
the jagged line W means "paper jam"
Posted on Sep 17, 2008
Why it prints grey background
Either the toner cartridge is very close to empty or the drum unit needs to be replaced. Check your warning lights. Yellow = toner, red = drum. If no warning lights, pull out the toner/drum unit and remove the toner cartridge. Have a look at the cylinder in the drum (DR2125) - if it is very black and matt looking you will need to have it cleaned or just replace it.
May 20, 2014 | Brother HL-2170W Laser Printer
My Sharp AL 1000 has quit copying!
The triangle or stack of 6 dots is the toner cartridge light. The drum light looks like a cylinder or aa battery.
If you open the right side door, then the front door you will see the 2 cartridges. The toner cartridge is on the left and should have a large green button you push down on to release and slide out. Later or when needed you can slide out the drum cartridge AFTER you remove the toner.
You might have a local source to get your toner cartridge refilled. Or just order a new one and unpack it, then slide it in and your all set.
About $50 for refill or about $100 for new.
Good Luck
Nov 25, 2009 | Sharp AL-1000 Copier
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
Paper keeps getting jammed and is covered with ink powder. Looks like part of the reel on the left side is broken on the cylindal shaped thing. Can that part be replaced?
That cylindrical thing is the drum; the drum is photosensitive, meaning it is sensitive to light much like film in a camera. If paper is jamming and is covered in toner, that means the drum is possibly losing its effective properties and it is not being cleaned properly. The drum can be replaced; contact a Xerox Rep for service.
Sep 09, 2009 | Xerox WorkCentre XD120f Copier
When i turn on the copier it is stuck on 10 copies and a light flashes to the left of the copy number. I don't have a manual. I don't know what the flashing light means.
If the light is a red light with a flash shape then the machine probably has a jam. Look for jams and once you have cleared any jams switch the machine off and then on again. It could be the toner light if there are about six red dots - in this case you need to add toner.
Jun 30, 2009 | Canon NP 7130 Black and White Copier
PERMANENT RED LIGHT pls, the light close to the meter is showing red light. that is the human being shape and the round sign
Hello sir; Is there have error code display on screen? if not means need periodical service,( need replace drum, cleaning blade, developer etc.).
May 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Red cylinder looking error message
That is the drum replacement indicator. Timing on those things can make a person insane at times.
You need to now replace the drum cartridge.
Mar 21, 2008 | Sharp AL 1631 Copier
Sharp AL-1641CS Lase Copier
http://www.retrevo.com/s/Sharp+AL-1641CS?rt=pd
Here is the location for your copier manual. You'll be able to view & download. Good Luck :0)
Jan 10, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL 1631 Copier Logo
188 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
