Question about HP OmniBook XE3 Notebook
HP Pavilion N5470 problem (can use the Omni X3 mainboard)
I have a laptop HP Pavilion N5470 and it won't turn on, the bat is fully charged and the power cord is connected . The power light is on but i cannot see anything on the screen . The fan starts up for a few seconds then stops Any help will be very much appreciated Thank you. Highlander
Press f11 or f10 when your laptop first turns on and maybe u can reset it
Posted on Nov 10, 2008
I have pavilion dv7 won't turn on
First, To put the laptop to charge the battery for least 1 Hour, if continue won't Turn on , apply botton power and ESC and active the troubleshooting its possible that ypour battery is die,
Jun 21, 2012 | HP Computers & Internet
Where is the part number located on the motherboard for hp pavilion n5470? It isn't on the top right of the board. Do I have to remove the cpu and the heat sink combo to reveal the part number for
Most times it is located on a white sticker near the memory slots. One would think that is for the memory slots. Sometimes it could be anywhere and sometimes it will have MB on the sticker along with a series of numbers and letters. Sometimes only portions of the number you see on the sticker might be used to identify the board.
Try the steps below to be sure.
Write down the numbers you see on a piece of paper. Then go on ebay and in the search box type: HP Pavilion n5470 Motherboard. When the search results come back look at the motherboard part numbers and find one that matches one of the numbers you wrote down.
I looked for your board on ebay and only saw the following number for the motherboard: F2409-60903
One other thing you can do is to go into the HP Support website and instead of downloading drivers when you get the site up look around for links that will give you your warranty or configuration for your laptop that they manufactured it with. Usually they will have the motherboard part number listed in the original configuration.
Get online and got to www.google.com In the google search box type: "HP Support" or "Compaq Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look at the links on the webpage and there will be one for warranty or configuration, specifications, etc. They will require you to put in the serial number and part number located on a sticker on the bottom of the laptop. Serial number will have S/N: Part number will have P/N: followed by a series of numbers and letters.
May 18, 2012 | HP (F2409-69003) Motherboard
Acer Aspire One won't turn on or charge, totally dead. DC power pack tested ok.
You probably get damaged the charging connector, or it is simple dissoldered from the mainboard, thats a very common problem. Check first if it turns on with another fully charged battery. If yes, you should resold the charging connector.
May 14, 2011 | Acer Computers & Internet
My Hp Pavilion Elite M9580a wont turn on. power light is on at the back but the light wont turn on
I recommend going through my guide it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
To me, off the bat, it sounds like a dead computer mainboard. However only purchase a replacement component when you know for sure which component it is.
Dec 21, 2010 | HP Pavilion Elite M9150F Desktop PC
System power won't stay on after power botton is pressed
hmm -- that sounds like a dead motherboard -- lets try some exercises
is the battery fully charged ? if yes, turn computer on without AC adapter
if not, take battery out and use AC adapter only
if that fails, its a mainboard issue (but not 100% certain)
can you give me your phone #, and i will call you -- i have to ask you a few questions concerning your system
also, give me your computer S/N (located on back of computer)
Oct 15, 2010 | HP Pavilion dv9823cl Notebook
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Motherboard compatability
i doubt it as the connections to the monitor may well be different plus the laptops are very different shapes meaning it wont fit inside unlike desktops laptops are no interchangable
Aug 06, 2009 | HP Computers & Internet
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
Turn LAPTOP ON
push the screen to you and push it away so far as he can.
you hear a click the screen is fixed
May 14, 2008 | HP OmniBook XE3 Notebook
HP OmniBook XE3 Notebook Logo
128 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
