Question about Compaq D51C PC Desktop
Need to reset computer
The computer keeps resetting itself once it reaches the windows load part. I just want to reset the whole computer. I dont want to keep any files I just want it to be reset to factory default settings or whatever you call it.
  • Lynne Lindsey
    Lynne Lindsey Sep 16, 2008
    No whenever I make any selection it just keeps restarting. I do not have any discs to reset it so I was hopeing there was a key for doing it.
  • Anonymous Oct 09, 2008
    i have the same problem. i can not get to boot menu f10 f8 it does not reconize. itjust continues to windows screen then resets itself
    Guru:
  • 558 Answers
Hi Emerald20061,
Could you able to boot it in Safe mode.
Tapping F8 Key during Startup. A black screen comes.
Let me know if it works in safe mode. I will suggest you accordingly.
Regards
ELLIN
Posted on Sep 16, 2008
Windows on my 2006 Saab 9-3 Sport keep reclining after a press the button to send them up, once they reach the top they recline to halfway open. Do I need to reset the computer and if so how do I do...
Hi Mike?
Turn the ignition on and end all the windows down and hold all the buttons down at the same time for 15 seconds, then take the windows up and hold the buttons up for 15 seconds. That should reset the computer..
If it does not work first time try it again.
May 24, 2011 | 2003 Saab 9-3
I have a thomson b94560 wi fi router and cant find the password for it to connect my kindle.
You may need to reset your router. Most routers will have a default username and password printed somewhere on the router itself. Once you find it find the reset button, usually a small whole with a recessed button inside. Use a pen or something small enough to reach the button and hold it down while the routers still on for at least 15 seconds. After which you will just need to reconfigure your router to the setting you had before. And don't forget to change your default admin password because the default passwords are usually readily available on the internet.
Mar 01, 2011 | Computers & Internet
I like to Restore System To Factory Default I have lost my Password to Empowering Technology for Acer Aspire M1610
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
or
Ebay you can purchase a Password Unlock/Recovery For Windows 2000/XP/Vista/7
Item title Password Unlock/Recovery For Windows 2000/XP/Vista/7
Buy It Now price: US $1.49 (Approximately AU $1.50)
also
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT. Click Restart when prompted. Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope it helps.
don't forget to vote
Feb 26, 2011 | Computers & Internet
I have an IBM ThinkVision 20" L200P LCD monitor. The OSD (On Screen Display) is corrupt and showing garbage characters. I believe it needs a factory reset to re-initialize itself but I cannot find...
Alternate:
or
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Hope this helps don't forget to vote
Feb 18, 2011 | Computers & Internet
I can't remember my log on passwaord for logging on ...I tried new admin password and reset pasword but when it loads up it goes right back to my name and asks me for my password ...I think my little brat...
Windows Password Recovery is right what you need in your case. The program is designed to reset Windows login password once you accidentally forgot it or have no access to your system. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove your forgotten password.
Jul 26, 2010 | Dell Inspiron B120 Notebook
Computer keeps restarting
If your are able to access Windows the Screenshot it and paste it onto paint and tell use what it says.
Apr 02, 2009 | Lenovo 3000 N200 PC Notebook
How can i keep my mp3 on so i can put music and videos on it
Make sure the hold/lock switch is not engaged.
Try another USB port.
If that fails:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 04, 2009 | Philips GoGear SA3125/37 MP3 Player
Numbering on my photos has change. how do i change it back
Hmm.. I dont think you can do that. The camera keeps a memory number itself once reset it starts 0001 again.
Dec 28, 2008 | Fuji FinePix F10 Digital Camera
Reformatting problem
Do you mean that you are re-loading windows? if you are when it reboots after re-loading and it says boot/start with cd-rom support do not press enter again or anything else for that matter because if you do it will keep taking you through the whole process again. Once it has loaded and reboots do not press anything it will start windows( even though it gives you the option to start with cd-rom support - just ignore it), itself and take you to the welcome screen etc... once this happens you can take the disk out.
Oct 25, 2008 | Computers & Internet
SanDisk Sansa E260: How do I reset the WHOLE thing?
Recommend that U get (purchase) a good anti-virus like Shield Deluxe to protect Ur system. Use Msconfig to cleanup Ur startup and use disk clean then defrag. Clean and defrag often, once a week. And keep in mind that itunes is a Mac program and nothing runs perfect on windows.
Apr 23, 2008 | HP Compaq Business Desktop dx2200 - P4 524...
Computers & Internet Logo
106 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
