Question about Canon PIXMA iP1600 Printer
Cartridge installation error
I received your solution. I do not accept it until I purchase two new cartridges, install them and see if that fixes the problem.
Robert Tomasso
  • 1 more comment
  • Yitzy884 Sep 16, 2008
    At your suggestion, I replaced both cartridges with new ones and still get the same error message. Can someone else on your team suggest something else?
    Robert Tomasso
  • Yitzy884 Sep 17, 2008
    To answer you question, when I attempt to print, the alarm light goes on and blinks 7 times. The message for that is, a cartridge is not installed properly. Open the printer cover and check the cartridges positions.
    I did that, and even removed them and reinstalled them. Still I received the same message. Therefore, I do not accept your solution, nor should I be charged for this problem. I will however, use your service in the future.
    I will attempt to resolve my problem this time, by going back to the store where I purchased the printer less than 2 years ago.
    Thank you for you attempt to help me.
    Robert Tomasso
  • johnnyariKI Sep 17, 2008
    I JUST BOUGHT THIS PRINTER TWO DAYS AGO WITH NEW CATRIDGE AND IM GETTING THIS MASSAGE CATRIDGE NOT WELL
    INSTALLED BUT I USED IT THE FIRST DAY PRINTED FEW PAGES 4OR 5 THE STARTED GETTING THE STUPID MASSAGE ABOUT THE CATRIDGE, WHEN I TURN IT ON THE CATRIDGE HOLDER MOVES ALLTHE WAY TO THE RIGHT AND NEVER COMES BACK AND MY TWO LIHTS ARE BLINKING ITS NOT EVEN 2 DAYS MEN COMMON JOHN SAY
    Scholar:
  • 148 Answers
Okay... is this the first time that you will change your printer ink???
Posted on Sep 16, 2008
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 16, 2008
    MAY YOU AGAIN INDICATE HERE WHAT TYPE OF ERROR YOU HAVE THERE...
    DO UNINSTALLING & REINSTALL AGAIN THE PRINTER DRIVER COMPLETELY.
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Brand new lexmark original cartridge is not recognised. error report' no cartridge'. all contacts cleaned machine dismantled and cleaned and reassembled. has done this before on occasion with refilled...
1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
2. Make sure the correct toner cartridge is installed for this printer model.
1. Check Lexmark for a list of compatible cartridges for your printer.
2. If the wrong toner cartridge is installed, remove it and install the correct one.
3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
1. Turn off the printer.
2. Reseat the toner cartridge.
3. Close the lid.
4. Power the printer back on and check the display.
4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
May 02, 2011 | Lexmark X2350 All-In-One InkJet Printer
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
    3. Close the lid.
Feb 15, 2011 | Lexmark C534dn Laser Printer
Phaser 4510 replace toner message won't print until new toner installed - new toner installed and still has the replace toner message
  • This product can be configured to use a metered or non-metered Toner / Print Cartridge. A non-metered machine requires a non-metered cartridge be installed to operate, while a metered machine can accept both a metered or non-metered cartridge to operate.
  • Make sure the correct cartridge is used for the machine. If you are receiving metered print cartridges but the machine will not accept them, contact your reseller or supplier to ensure that your machine is properly set up as a metered machine, and that the metered PIN has been entered
  • Make sure you don´t have any stickers on the toner box.
  • If you sure all paper and stickers are out then reset the nvm values from the device in order to reset the printer information.
Aug 27, 2010 | Xerox - PRINTERS - PHASER 4510 (N) LASERPR...
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Cartridge Error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
-open cartridge door and remove the cartridge
-unplug the power cord at the back of printer
-after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
-Open the cartridge door and insert the cartridge
-close the access door
-if the error is cleared, try faxing again.
I hope this helps.
Regards,
Mar 02, 2009 | HP 640 Inkjet Fax Machine
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cannot get the printer to accept the new HP black cartridge
Make sur u r not using refilled carts...
Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier..
And install the carts thru the HP software..this might fix..or the carts are defective
Jun 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Cartridge Error
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Canon PIXMA iP1600 Printer Logo
48 people viewed this question
old marine
old marine
