Question about Denon AVR 3808Ci Receiver
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI cable on the DVR to the HDML DVR1 or TV/CBL input, and connect another HDMI cable from the Monitor (output) to the tv, I get audio through the surround speakers but no picture on the television. I am not very tech savvy and am unsure what to do to get the picture to display on the tv properly.
    New Friend:
Solution #1 is wrong! I have been running my DISH Hopper DVR, via HDMI, thru my 3808ci for the past year and a half. You must choose the correct input on the Denon (i.e. SAT or DVR or whatever) and ensure that that input is set to use the HDMI port (1,2,3 or 4) to which you have the DISH equipment connected.
Posted on Jun 24, 2014
    Scholar:
  • 69 Answers
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Posted on Sep 21, 2011
SOURCE:
Why wont my surround work with new Dish network dvr.
When the DISH Network installed hooked up their DVR, did they connect it via HDMI? If so, then it could be a bad HDMI connection. I would bet they simply bypassed your receiver and went straight to the TV, which is why no audio comes out of your receiver. You can test this by turning on your DVR and TV. If you see picture with your receiver OFF, then they bypassed your receiver. You'll need to hook up and HDMI cable from the DVR into the receiver and then out of the receiver to the TV.
Feb 21, 2016 | Denon AVR2112CI
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
Dish HD-DVR connected to a Denon 3808ci via an HDMI cable. Problem is periodically, the screen goes black for a split second and then comes back. Rewind and play again the blackout doesn't repeat. When...
Your'e losing digital data from Dish or the DVR. Since even live TV is through the DVR it is always a potential problem when anything glitches. That it doesn't repeat on immediate rewind/playback says the data made it to the hard drive ok.
The Denon is only defaulting back to an analog audio feed upon loss of the digital (preferred) one.
If it affects the video AND audio simultaneously the cause is something common to them.
I'd look at HDMI cabling into the Denon from the DVR.
Don't blame the Denon just yet.
My $.02:
I'd skip the video right past the Denon to the TV/Monitor even if it means using component cables instead of HDMI, but keep digital audio coming in from the DVR. Added cabling and connections never improve anything. Plus, HDMI cables are expensive.
It would be interesting to see if the problem comes back and affects only the audio or the video.
If you use optical cable make sure it has smooth flowing curves and no small-radius bends that would lose light power.
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
Feb 06, 2011 | Denon AVR 3808Ci Receiver
Digital projector is shutting down as soon as dvd
Hi make sure that in the projector menu it doesn't have an option to cancel "control" as many tv's with hdmi have the capability to receive command signals through the hdmi cable.
Also make sure that your receiver is set for hdmi signal you must designate which input you are using on the receiver and then tell it what type of signal you want it to use.
you may have just pushed a button that changed these settings somewhere along the way.
hope that helps
Dec 30, 2009 | Denon AVR 3808Ci Receiver
I have a Denon AVR-3808CI A/V receiver, a Samsung HL67A750 DLP TV, a Samsung BD-P1600 Blu-ray player, and a Motorola HDPVR for the cable signal. I have connected the Blu-ray player and HDPVR to the Denon...
You will have to disable one or the other. Most likely the source because not all disk"s will be recorded the same. If a disk was transfered from film to digital poorly, this will show up as a grainy look on your tv, not much you can do about that. I would set your tv the best possible and go with that, also if your tv is capable of 24fps use that setting.tweaktv.com can help you with your tv setting. Use Progressive Mode on you blueray and your dvd also.
Apr 24, 2009 | Denon AVR 3808Ci Receiver
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
HDMI connection???
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
solutiondoct
May 28, 2008 | Denon AVR-2807 Receiver
Denon AVR 3808Ci Receiver Logo
512 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
