I can log on to the computer, and got to new task and get to the internet,but my desktop is blank including the start button.
  • 3 Answers
Try Logging on as Guest OR reinstall windows but if thats going to far check out this site!
http://www.softwaretipsandtricks.com/forum/windows-xp/8320-blank-desktop-no-desktop-after-log.html
Posted on Sep 16, 2008
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
Had a virus got rid off it but now screen is white and cannot do anything with it
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Aftr i start n log onto my pc... I can see d mouse but d entire screen is blank!!! Pls say what to do
We wish you a merry Christmas and a Happy New Year.
Which is the operating system?
What exactly happens when you start the PC?
Is it Blinking cursor with a black screen?
Then its black screen error.
Firstly, there appears to be many causes of the black screen issue. The symptoms are very distinctive and troublesome. After starting your Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system appears normal. However, after logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see.
If you have these symptoms you can safely try this for free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below:
1) Restart your PC
2) Logon and wait for the black screen to appear
3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this)
4) Press the CTRL, ALT and DEL keys simultaneously
5) When prompted, Click Start Task Manager
6) In Task Manager Click on the Application Tab
7) Next Click New Task
8) Now enter the command:
"C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com
/download.asp?GRAB=BLACKSCREENFIX"
Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it.
9) Click OK and your browser should start up and begin the download process
10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue.
11) Now restart your PC and the black screen problem will hopefully be gone.
Hope this helps.
Cheers!!
Dec 31, 2010 | HP Pavilion dv6000z Notebook
I have a Compac computer that has Windows XP installed (SP2), when I start up the computer, the Windows XP will not run correctly. Once it seems to be opening Windows, my computer screen just looks blank...
When you are on the blank screen try to press CTRL+ALT+DEL on your keyboard at the same time. it should bring up the task manager window. now, click on FILE > New Task Run > Type in EXPLORER.EXE and press Ok. it should show you your Taskbar, desktop wallpaper, desktop icons
Oct 01, 2010 | Computers & Internet
When my wife turn on the computer and log in her password, the monitor did not display all the icons, it is just a blank screen. what s the problem of my wife's computer?
Explorer has not been started automatically as it should have.
Press Alt+ Ctrl+Del to open Task Manager, click File, Click New Task, type explorer , click OK.
Aug 20, 2010 | Acer Computers & Internet
Blank desktop
Just simple that it is not contain explorer process
go to task manager then new task then write explorer then enter
Apr 29, 2009 | Microsoft Windows Vista Ultimate Edition
Blank screen, can only start programms by task manager
Try to boot Vista into Safe Mode. Tap the F8 Key right after you turn on the computer until you get the Advanced Boot Up Menu
and use the keyboard arrow keys to select Safe Mode. The next screen may ask you to select your operating systm. Select Vista, not the Recovery Console.
Does your task bar and icons appear in safe mode? If so, it might be one of your start up programs that is failing and causing explorer.exe to fail during normal boot-up into Windows and not allowing your taskbar and icons to appear. Click Start and type in msconfig and hit enter then click the Start Up tab and look at all the programs that start up when Vista is starting up. Do Not uncheck anything in the list that you do not recognize as you may uncheck drivers or Vista starting programs that you computer needs to start up Vista properly. Google anything you don't recognize and uncheck any Start Up programs you do not need to start when Vista boots up, like Quicktime player or Adobe Reader for example. (This would also help your boot up time into Vista)
Sounds like explorer.exe crashed. Try opening up the Task Manager again, and Click File > New Task and type in explorer.exe. See if the task bar and your desktop icons appear.
If they appear for a brief moment then disappear again, the Windows explorer.exe is corrupted. Explorer.exe will try to start and then fail again. You may need to use System Restore to bring your computer back to a date and time when the computer was working properly, before the Vista update.
Jan 31, 2009 | Computers & Internet
Desktop icons and start button issue
Hit CTRL-ALT-DEL
Task manager will come up.
Then click File, New Task.
Then type explorer.exe
This will load the things that you're missing. These things are probably missing because you have a virus. Make sure you do a scan.
May 20, 2008 | E-Machines eMachines Desktop PC
Blank desktop, no start button
open task manger > applicatiins tab > selct new task> type explorer then ok then the desktop will coome uo
Dec 22, 2007 | Northgate STAC2217L (Bundle) PC Desktop
Active desktop recovery
It sounds like there is something causing the process explorer.exe to not start properly. Most likely a virus, but could be something wrong with windows itself. First of all, when you get to that white screen and there is no toolbar down the bottom, bring up the task manager (press control alt delete) and click the new task button down the bottom. Then type in explorer.exe and hopefully that will start up the toolbar down the bottom of the screen. you can also use the new task button to browse for any anti-virus program you have to run a scan to see what is causing the problem.
Oct 17, 2007 | Toshiba Satellite A75-S213 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
