Question about Terk LeapFrog LF30S
TERK LF-30S Interference
I have contected the unit from my DVR to a projector in another room and I am getting a flickering picture, and worse, a consistent loud buzzing. The units are set to the same channel, the antennas are facing each other, and the 2 units are only about 20 feet apart with only 2 walls between them. I have cordless phones but they are on a different frequency. I unplugged them anyway but there was no change. Any suggestions? Thanks.
2 Suggested Answers
danbusa
  • 185 Answers
SOURCE: I have a Terk LF
Hello this is Dan Busa with DISH Network. I'm not quite sure if this is the answer you need, the way you need this set is you want the IR blaster pointing directly at the IR sensor on your receiver (the three holes by the power light) the actual extender just needs within close range of your remote.
Posted on Jan 15, 2011
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Canon lv-5220 multimedia projector flickering after start up
If it happens with no input hooked up then it could be the lamp. Or Worse.
Dec 05, 2012 | Canon LV-5220 Multimedia Projector
I have a Terk LF 30S and have it connected to a Dish Network 311 and is transmitting to a Vizio LCD. I am having issues setting up the IR Extender ... I have no clue where to set it on the Sat Box.
Jan 10, 2011 | Terk LeapFrog LF30S
TW cable remote does not work after Mitsubishi LCD TV turn on
Yes, try that. It is easy to do and doesn't cost anything. You've tried new batteries in the remote as well right? There are two types of remotes, IR (Infrared light LED is used) and RF (Radio Frequency). With an IR unit I do not see any way there can be interference as long as you don't have an IR lamp around the TV and TW DVR box. On the other hand, with RF, depending on where you live and other factors, there could well be RF interference. You'll have to locate the interference and remove it. In this day and age, things such as LED and CF light bulbs DO cause RF interference. If you use these kinds of lights in the room AND you know that the remote is an RF remote then try turning all the lights off in the room and try again.
Oct 05, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Two projectors controled by one computer and one is fuzzier.
This is only a theory: Assuming that this setup is in an office, there is a high probability that the lighting is fluorescent. This type of illumination is NOTORIOUS for causing AC interference with video signals. It is hard to suppress because there are AC lines *all around* acting like antennas. If you use shielded video feeds, make sure all circuits are properly grounded(and *isolated* in extreme cases) to minimize EFI. (electrical frequency interference) The fact that 2 projectors are connected to a single computer lends credence to an interference problem--grounding is usually the culprit--not the computer, but all the junk connected to the ground wires--fans, lights, air-conditioning motors, refrigerators, you name it...You might want to check into getting a power conditioner or filter to "clean up" the electricity in that particular room. Video and audio signals are delicate--just turn up the sound loud, with nothing being broadcast, and listen to the AC hum in the static. Those are my thoughts anyway...hope I was useful!---rick
Sep 08, 2009 | NEC MultiSync NP2000 LCD Projector
Clicking
the colorwheel needs replacing. the motor bearings are going. if the colorwheel slows down (due to bearings or interference) and doesn't sync up with the dmd chip, the pic will flicker until it does. also clean out the projector and see if there is any debris obstructing the colorwheel.
Aug 08, 2009 | Dell 2200MP Multimedia Projector
I have a MacBook Pro and a XR-30s sharp projector. When using the DVI port on the Mac to DVI-D on the projector the picture turn grainie. WHY? However, when I disconnect the cable, the pix clears up on the...
It is probably mirroring the screens on your MacBook and the projector. If you want different resolutions and things on each screen, go to the Apple menu, System Preferences, Displays, Arrangement and uncheck the "Mirror Displays" checkbox.
Apr 22, 2009 | Sharp XR-30S Projector
Sharp projector XR 30S stanby
Sounds like the lamp needs to be replaced.
Re your Sharp XR 30S We are able to supply replacement lamp delivered (excluding local your local taxes) for $US270 as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens.
http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Feb 11, 2009 | Sharp XR-30S Projector
DVR CCTV
  • This is caused by pore voltage (not enough amperage to the camera) check for bad connections or shorts. thundersecurityonline.com
Aug 21, 2008 | Televison & Video
Terk LeapFrog LF30S Logo
198 people viewed this question
Top Terk Televison & Video Experts
Are you a Terk Televison and Video Expert? Answer questions, earn points and help others
