Question about HP Compaq Presario V2000 Notebook
Blank screen thanks for responding. So u think it might be overheating?. should i chage the motherboard first or the inverter? i know the inverter is easier to replace (and cheaper) but i didn't know it could overheat.
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Please see this reference, as it is a known and identified issue with this model at HP:
Your issue is most likely a defective machine, and HP should assist you with repairing it or replacing it as appropriate. If you do not one of the specifically identified product numbers, or in a different location, you still have a solid case for getting it corrected. The documentation is there that the product is defective, and HP needs to correct it for you. Good luck - I hope it goes well!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 26, 2008
Dimmed screen
u check the fues inverter if inverter is ok u check fues near the main board cable jeck
thanks if no solve u must chage the inverter
Feb 20, 2011 | Acer Aspire 4315 Notebook
I have an hp\compaq presario c300 it doesn't show image on the notebook screen but i'm able to see image on the external monitor. I have replace the lcd screen and the lcd screen inverter, also made chage...
By using an external monitor, you have shown that the computer/video adapter is fine.
I'm wondering if you have told the computer to send the image to the LCD screen--using the Fn key and the special function key combo that directs the image to the LDC, the external monitor, or both.
It could also be the connection of the LCD monitor to the motherboard. You would do well to check that connection.
Oct 25, 2010 | Dell Latitude X300 Notebook
I have an HP Pavillion dv9000. I RARELY use it, but my screen is blank. The power and lcd lights come on, but the screen is blank. I've taken the battery out, connected the power cord and turned the...
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Test with an external monitor attached to the laptop. If you get display on the external monitor, then this confirms the case.
Aug 21, 2010 | HP Pavilion dv9000z Notebook
Lcd blanks out
Yes, that is one possibility. It could be the cable from the motherboard to the display. Inverters are fairly common problem.
May 14, 2010 | Toshiba Satellite 1805-S204 Notebook
Laptop display goes blank after a second, not lcd inverter
I have had a similar issue with an LCD monitor and the issue was not with the inverter itself but the backlights. They can go bad and short (which is where my issue was. Once they were removed the screen was working again (the lights needed replaced).
Hope this helps!
Nov 08, 2009 | HP Pavilion tx2500z Notebook
Water damage touch screen not working think its getting worse as sometimes does not read game 1st time and screen goes blank sumtimes 2
Water damaged screen means total loss, You must have to chage screen. First time while you switch on it water is presented on TFT display, And its damaged to diplay & normaly is blank sometime. Check it in service center of it.,
Sep 23, 2009 | Nintendo DS Lite Console
While watching tv, the screen went blank. What
we had a similar problem on our 40 inch samsung , the screen went black but we could still hear sound on ours it turned out to be the main board not the inverter like some people liked to think thanks
Jun 30, 2009 | Televison & Video
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
Video card works then goes blank and then works and goes blank...i get an "ATIKMDAG stopped responding but recovered"
It could be caused by a driver issue or overheating according to the ATI website. Hope this helps.
Jan 20, 2009 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
