Question about Panasonic Office Equipment & Supplies
I have a panasonic fax/answer phone mod No kx-f2060 it only prints about one side of paper i think it needs new thermanal head if so can you supply this
    Genius:
  • 2,120 Answers
That part probably does not exist anymore.
Posted on Sep 17, 2008
How do I delete stored faxes in a Panasonic KX-FL511 without printing them?
The manual indicates where you may need to reset the unit if the memory is full or even if you just want to clear it, page 89-90.
You may use code: [MENU] [*][8][0] [SET] or [START]
You may also call - 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
Mar 04, 2015 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic kx-fl511 has blank vertical lines on fax when printing.
It's important to gently move the toner cartridge from side to side to distribute the toner evenly through the cartridge. This could be causing your blank lines. Also, clean the Corona wire when installing a new toner cartridge. Best of luck.
Greg
Jun 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax thinks it has printed from memory.
no, once the machine thinks it has printed them there's no way to retrieve them
Jan 22, 2009 | Panasonic KX-FP205 Plain Paper Fax Machine...
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
Fax problem
left side is printing and right is not printing.first clean thermal head after this check cover locks may bi right side cover lock is broken .just press from right side and make a copy .otherwise replace thermal head .MIAN AKHLAQ
Dec 18, 2008 | Panasonic KX-FP80 Plain Paper Thermal...
Fax machine does not print on the right side of paper
Probably the thermal head is bad. It's a spring loaded bar inside of the fax machine. You might be able to shim it closer to the paper on the bad side.
Oct 20, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Printing not working well
the thermal head, scanner and the body. should be given focus on this problem. if the scanner is not copying well it needs cleaning by wiping the glass part with a alcohol in a cotton bud. if the scanner is really okay then the thermal head is not printing properly so it needs a thermal head replacing . or both are okay. the body is having problem. there must be a dis allignment on the said components. then this is the time to bring your fax machine to the panasonic shop center to do a further check and replace what is needed to be replace.
also try to check if you installed the toner and drum properly by following the installation instruction.
hope this could help you.
Mar 29, 2008 | Panasonic KX-FLB756 Plain Paper Laser Fax
Panasonic KX-FPG376 Plain... Problem:
Thermal paper roll upside down. You can only print on 1 side of thermal paper. also could be the thermal head in which case not worth repairing. Lawrence
Mar 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
for printing of this machine ttr roll is use you check with another quality of that like canofax roll and cheak out for machine printing.
Mar 11, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
