Question about Brother MFC-5840CN All-In-One InkJet Printer
Print cartridges Hi I put all new print cartridges in my 5840cn and it won't print cause it tells me they are empty. What can i do? Thanx
    Scholar:
  • 148 Answers
  1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
  2. Lift the top cover to the open position until it locks securely into place.
  3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
  5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
  6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
Posted on Sep 16, 2008
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 18, 2008
    KEEP ME UPDATED IF YOU NEED MORE ASSISTANCE ON THIS. I'M WILLING TO HELP YOU AND SORT THE THINGS OUT IF I CAN..
    LET ME KNOW IF MY GUIDED SOLUTION I PROVIDED HERE DID NOT SOLVED YOUR PROBLEM.
Won't print because color is out, I have setting on black only shouldn't that work?
i think all printers do not print if one of the separate color cartridges is empty. check ink and replace. hope this will help.
Apr 02, 2012 | Canon PIXMA MX310 All-In-One Printer
I have just put a new tonor cartridge in the printer but it still gives the message tonor life ended please replace cartridge
Hi
Just follow this steps.
Turnoff your printer for 2-5 mins and remove the toner cartridge, then put it back firmly. Then open your printer and try to print again. That will refresh the memory of your printer.
Jan 13, 2011 | Brother MFC-5840CN All-In-One InkJet...
Hi! I has refill my ink cartridges for canon mp490 printerbut I don't know how to reset it to make it print.i know you may have more idea then me.thanks for your help.thanks
Welcome to the world of Canon. Simply put, the PG-210 CL-211 cartridges have what I like to call "digital fuses" built in. One fuse for "new" and one for "empty". When you install a new Canon cartridge both "digital fuses" are intact. The "new" fuse tells the printer that it is a new genuine Canon cartridge and resets the page counter internal to the printer. With the page counter reset, the printer "blows" the "digital fuse" and that cartridge enters the used state. When the page counter on the printer believes the cartridge to be completely empty it will "blow" the second "digital fuse" and the printer will from then on refuse to recognize it as a valid cartridge. Some claim to have ways around this, but Canon really has won this battle. My Cartridge World store does not refill these cartridges and does not recommend refilling them. Buying original Canon cartridges is what we recommend.
Jun 14, 2010 | Office Equipment & Supplies
I have replaced all cartridges-Black, yellow,blue,cyan ; however, print message indicates replace yellow.
The head of the printer may be defective that's why the cartridge is not detected by the printer.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Ink Cartridges are full but keeps telling me they are not to then
as a printer mechanic .i had got many customers coming at my work shop with this problem .and it gets soved by replacing the cartridge with new cartridge.as you said cartridges are full still it says change cartridges.but if the circuit of the cartridge is got faulty it will not print let it be full.so clean the brown colour metal circuit on the cartridge with a dry tissue.if its due to dust got stuck up on the circuit it will print otherwise the cartridge has to be changed in this case.
Feb 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Ink level status on black ink is not accurate
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
New ink cartridges not printing
hi,what kind of printer u used?,,,,i think u must repel the cartridges before using it.
Aug 19, 2008 | Brother MFC-5840CN All-In-One InkJet...
Red not printing
The only thing I can suggest, short of replacing it, is to shake the cartridge, hard. That sometimes will clear interior clogging. If you see fresh ink on the bottom, you're on your way. Put the cartridge back in and run another cleaning.
Mar 23, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
278 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
