Question about IBM NetVista PC Desktop
Error code on booting
When I am trying to boot my Pentium 3 computer,I get an error code "110 F000:AA25",I cant even go to BIOS.Please specify whats the problem.
  • 781 Answers
It may be a memory board error.. you may have to replace the motherboard
Posted on Sep 20, 2008
I installed a 500 mhz pentium 3 cpu on a IBM 36L9059 motherboard now I get an error when I boot up CPU BIOS update code mismatch How can I clear the error
GOOD DAY..!! pENTium 23 right now is not existing in tha market but since you encounter its problem,i think best solution for that is to buy a new one coz pentium 3 parts is hard to find in the market..thanks
Aug 17, 2011 | IBM Computers & Internet
Gateway pentium 3 boots to where it displays cdrom drive infromation then it pops up a blue window asking for a pass code. What is the code it requests or cause of problem?
Sounds like a bios password thats only thing it can be pre-boot screen. If its a desktop you can dislodge the bios battery for about 3 minutes if its a laptop your kinda screwed. If you can prove ownership of the laptop then maybe Gateway has a master password work around.
Jan 04, 2011 | Gateway Computers & Internet
Acer aspire 1600 four error code on pre boot then
Please reseat your RAM, and your CPU. Also check that the CPU is locked tight and that the RAM is seated properly. Run off A/C without battery then test with Battery only then with A/C on and battery connected.
May 22, 2010 | Acer Aspire 1604LC PC Notebook
Error message asks me to insert the boot disk. I
Your laptop bios may not be booting into the operating system drive or your drive partion may have an error.Try entering into the bios and checking to see that the boot order is still set to boot from Drive 0(Hard drive).During boot up,the bios looks for command to find the first boot device specified according to system settings.You can enter into the setup by tapping the Delete key when u first power up your computer..please let me know how u make out:)
Apr 12, 2010 | ASUS Eee 4G Notebook
XP wont boot and i cant boot from the restore disk. I get error code 1000-0146 when i run the DST Short test
That error code sounds like the Hard Drive is failing or has failed. Can you boot into Safe Mode? Hit F8 as you power up and choose Safe Mode with Command Prompt. If you can, enter chkdsk /r at a command prompt (the black window you'll see). You say you can't boot from the restore disk - why not? Are you booting to the green Dell Windows XP disc that shipped with the computer? Check the boot order in Setup (the BIOS) and make sure it looks to the CD drive first before trying to boot to the hard drive. SpinRite is a good utility for fixing these things, but not free, and involves booting to CD. http://www.grc.com/cs/prepurch.htm
Hope this helps!
Mar 08, 2010 | Dell Latitude D610 Laptop Computer -...
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
Which key to press at startup to gain access to BIOS E2180 Intel
There are a number of keys used to access the system BIOS at startup. F2 is probably the most common, but I see you've already tried that. I've also seen the ESC and DEL keys used, so try those. If that doesn't work, start working your way across the F1-F12 keys.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 13, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
I accidentally changed my CPU clok frequency from 100 to 250 and now my computer won't boot?
Ok I realize this is old and you may have given up by now or gotten it figured out, but I'm gonna try to help even with that being said, first of all I just recently had the same problem, this is a sure fire way to fix your issue,
step one, open up your computer so that you have access to the motherboard,
step two, find the system battery.
step three, near the battery there should be a jumper, this will be a little plastic piece with metal connectors inside it, it should be slid onto two pins out of three available, move it over one space meaning if its on the left and middle move it to the right pin and middle pin, the three pin pole should say cmos right by it, or clear cmos.
step four remove system battery, no need to worry this is just the memory for the cmos chip and it will revert it back to when the board was new, you can change the settings in your bios program back to what they were when it last worked,
step five, making sure that your power cord is not hooked up to the computer in the back, (no power to computer) press and release your power button a few times, (this will drain the capacitors stored power)
step six, walk away for about 20 minutes, just to make sure that clearing of cmos was a success,
step seven, replace cmos battery.
step eight, move jumper back to original possition.
step nine apply power to the computer and boot up should be operatioinal again, you can then go back into your bios setting and change as wanted, however I would only overclock a little at a time as boards will only handle so much overclocking before they will freeze up, i would not go more than 200 mine froze at 200 so you may not even want to go there, Hope this helps.......
May 18, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
IBM NetVista PC Desktop Logo
469 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
