Hello
Try using the onboard video chip to run your graphics.This will tell you if the agp card is bad or not.
Remove agp card first.
Also if there is another power supply for agp card fan, try using it.
I have used circut board cleaner on vid cards to get the fan working again with sucsess.
A few ideas.
Testimonial: "tnxs for ur time"
What i said was.take out agp card. Use onboard graphics.This will verify a problem with your agp card.
Thanks alot for the 2 thumbs..................
the onboard one dont give singal to the screen i reset cmos already but it dont help
tnxs for helping so far
Ok.hold on.This is not a graphics card issue is it? No beeps No signal .Try pulling your memory sticks.One at a time.Pull one .Then boot up.If machine works its a memory stick.IF it does not,pull the other stick but put the first one back in first.
Also recheck all your connetions to your hard drive and cd or dvd drive.A loose or bad cable will also cause this problem.
memory i check i put 2 working 1 in it
i disconect all cabels nrml i dont need then to get video singal i meen or am i wrong i will check whit cabels
cables from cd dvd i mean and harddrive
oke i pluged all right in and stil no video signal it looks like the onboard card is broken or the mainboard is broken but all fan are working i hear de harddisk and wenn i put the (broken) agp card in. it wants to start but make sound so seens to me like mainboard is working
Main board is working. How about the monitor? IF you took out your agp card and plugged the monitor video cable into the motherboard video input.You should have graphics or video.
Is it possible the monitor is the problem? You can hear hard drive,you have green lights on mobo. It has to be either the cable for the monitor or the monitor itself.
i used new cables
the monitor works whitout any problems on other pc
Do you have another or can you borrow another monitor? To verify its not the monitor.This motherboard has onboard video?
yes i tested whit both my computers the monitor works fine i try 2diferent monitors what are working
this motherboard has onboard video yes but i cant get it to work after the agp one is removed that why i tought it was a bios setting and thats why i cleant cmos but stil notting i hope a new agp card wil do the trick
ok.good.but does this motherboard have a video input.? instead of using your agp card ,can you plug the moitor video into the motherboard? most asus do not.but some do.
ok.can you see the bios screen when you boot up?are you able to get into the bios?
yes it has a input for video on the motherboard but thats one dont give singal that wat i try to explain
i cant get it to work on mainboard
no cant get singal from video so dont see bios
You need to get into the bios by holding down the delete key while booting up.Once there change graphics to onboard.
Another longshot solution is to take your agp card and clean the gold tips with a pencil eraser.Then try the agp card.
i dont get a boot screen or something like that so i cant press delete to see bios
i will try to clean the agp card
when you reset bios did you pull battery out for 30 seconds? Try that. If still nothing then try cleaning the agp card.
Or you may need a new card.Sorry i could not do more here. Good luck.
yeah battery i tryed thats what i mean by cleaning cmos and set jummper to clean i will try whit a new card
i dont get singal on the onboard and the apgcard is broke loke i told before i reset cmos because it wil set de onboard back erverything else seens to work i have green light on mainboard and no error peeps
so i take the agp card out and want the onboard to work
