Question about Intel Computers & Internet
Sound n video driver
Where can i find drive for sound n display,,wifi,, n network adaptr....plzz help me....i got PM965/GM965/GL960...GL860 CHIPSET....
    Scholar:
  • 148 Answers
Acer Extensa5620z originally had Vista, I wiped the hard drive and installed W7. Its not as simple as I thought. Now I need to update drivers and Acer.com doesn't have anything listed. In the det
Windows 7 should automatically install device drivers for the Audio, Video and Network, If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the internet for the driver.
4. Reboot your computer.
Mar 19, 2013 | AU Optronics Acer Extensa 5620-4801...
Change graphics card vostro 1710
Some laptops do have a graphics card that is mounted to the motherboard, with it's gold plated contact pins.
The pins slide into an expansion slot on a circuit board, that mounts to the motherboard.
Removable, therefore deemed may be upgradable.
Most however are like Chris stated, and are mounted to the motherboard with a BGA surface mount.
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the Red ->
Take a few minutes to view the IR 650 demo video. (5 minutes)
Shows you the IR 650 BGA Rework Station at work, but more importantly shows you the BGA surface mount; Solder Balls, and Copper Pads.
http://en.wikipedia.org/wiki/Ball_Grid_Array
IF, your Dell uses Integrated Graphics, the motherboard chipset is an Intel GM965 chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_mobile_chipsets
Intel GMA X3100 integrated graphics.
http://en.wikipedia.org/wiki/Intel_GMA#GMA_X3100
Means the G.P.U. is integrated in the Intel GM965 motherboard chipset.
Nope. No upgrading of that baby.
IF, your motherboard chipset is an Intel PM965 chipset, it uses Discreet Graphics through a PCI Express bus,
Means the laptop comes with an Nvidia GeForce 8600M GT graphics chipset,
http://www.dell.com/us/en/bpi/notebooks/vostronb_1710/pd.aspx?refid=vostronb_1710&s=bpi
Here we can see the Dell Vostro 1700 series of Notebook PC's, uses a separate graphics (Video) card, (IF your laptop came with this option)
http://www.ebay.com/itm/Dell-DY445-VOSTRO-1700-INSPIRON-1720-nVidia-GeForce-8600M-GT-Video-Card-256Mb-/120955693339?pt=PCC_Video_TV_Cards&hash=item1c2985691b
The green circuit board of the Nvidia GeForce 8600M, you can barely see.
The aluminum metal plate on top of it, is attached to the copper Cooling Tube, then to the finned rectangular Heatsink.
[Heat is drawn from the graphics chipset {GPU} on the graphics card, to the large aluminum metal plate. The plate absorbs the heat, then transfers the heat to the copper Cooling Tube.
The Cooling Tube is a slightly flattened copper pipe, sealed on both ends, and filled with Nitrogen gas.
The Cooling Tube absorbs the heat from the plate, then transfers the heat up to the finned rectangular Heatsink.
The finned Heatsink absorbs the heat, then radiates it away with it's thin fins. Air flow from the Fan Assembly, helps carry away heat from the fins of the finned Heatsink ]
This is what the Nvidia GeForce 8600M looks like, not attached to the cooling assembly,
http://www.ebay.com/itm/ASUS-NVIDIA-GeForce-8600M-GT-8600mgt-512-MB-512M-DDR2-MXM-II-Graphic-Card-f-F8SV-/330701665242?pt=PCC_Video_TV_Cards&hash=item4cff5af3da
You can see plainly that this is a graphics/video card.
Four mounting holes, and gold plated contact pins on the bottom.
The actual term is graphics ADAPTER card. The Brownish/Red square you see in the middle/bottom, is the graphics chipset.
[ The actual G.P.U. or Graphics Processing Unit, is the black chipset in the middle of that brownish/red square, has Nvidia in white on it, and white characters on the bottom -
***-***-XX.
X's used because I can't read it.
The brownish/red square around the GPU is a small circuit board.
ALL GPU's have to have a small circuit board, in order to mount to the motherboard, or a graphics adapter card. Also for electrically connecting the GPU to a motherboard, or graphics adapter card.
GPU,
http://en.wikipedia.org/wiki/GPU ]
In conclusion;
1) Depends on what Intel motherboard chipset you have, right off the bat.
Intel GM965 = No
Intel PM965 = Maybe
2) Intel PM965? Then your laptop should have the above Nvidia GeForce 8600M GT, with graphics adapter card, and cooling assembly.
2A) Does that mean you can change the GeForce 8600M GT?
Maybe. You need a BGA Rework machine, and better Nvidia GeForce graphics chipset. You're talking Ka-Ching here. $$$$$$$$$$
Probably have to stay within the same Fabrication Technology in nm.
(nm = NanoMeter. 1 Billionth of a Meter)
The 8600M GT is 80nm fab technology.
So is the 8700M GT.
When you get to the 8800M GTS, it changes to 65nm.
That's the architectural size. Doesn't state all the technological features that changed with it. (80nm to 65nm)
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_8M_.288xxxM.29_series
Means your BIOS program probably won't handle it, and doubt there is a BIOS upgrade for it.
3) Better graphics adapter card, and graphics chipset?
Again, that IMHO would only be an Nvidia GeForce 8700M GT, and NOT worth the trouble, believe me.
So that's it? No chance of upgrading your graphics? No, not so.
More information in an added Comment.
Regards,
joecoolvette
Aug 15, 2012 | Dell Vostro 1710 Laptop
HOW MUCH DDR2 MEMORY FOR LAPTOP
Referring to a Toshiba Satellite Pro L300 series of Notebook PC:
According to the Service Manual;
1) The Maximum Total Amount of Ram Memory depends on the Northbridge chipset used.
(System Controller. Intel)
If it is an Intel GM965 chipset, the maximum total amount is 4GigaByte. (4GB)
If it is an Intel GL960 chipset, the maximum total amount is 2GB.
Northbridge chipset (Or System Controller)
The Northbridge chipset was aptly named so, because of the general location of the chipset on the motherboard.
It is generally located under the Processor.
(The Southbridge chipset is located further 'South' on the motherboard)
The Northbridge chipset handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-Speed graphics.
High-speed graphics being AGP or PCI-Express.
Integrated Graphics, or a graphics card installed into a PCI slot is NOT high-speed graphics.
This is handled by the Southbridge chipset.
The Southbridge chipset handles the slower capabilities of the computer.
Motherboard diagram;
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
Information on the Northbridge (computing),
http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Information on the Intel GM965, and GL960 chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_Mobile_chipsets
Look under the heading Chipset at GL960.
Looking across you can see that the chipset supports;
1) DDR2 Sdram that is either 533MegaHertz, or 677MHz. (SO-DIMM ram memory for laptops)
2) Supports up to 3GB
[ Your laptop has TWO ram memory slots. The primary, or Main ram memory slot, (Outside edge), and the Optional ram memory slot, (Inside towards the middle)
There are No 1.5GB ram memory modules. ('Stick')
This is why 2GB is the maximum with the Intel GL960 chipset.
Install one 2GB ram memory module in the Main ram memory compartment,
OR,
Install one 1GB ram memory module, in the main ram memory compartment, and one 1GB ram memory module in the Optional ram memory compartment ]
Now look under the Chipset heading at GM965.
1) Supports DDR2 Sdram at either 533MHz, or 677MHz.
2) Supports up to 4GB.
How to know what Northbridge (System Controller) chipset your laptop uses?
Use CPU-Z from CPUID.com
Information on CPU-Z on Wikipedia,
http://en.wikipedia.org/wiki/CPU-Z
CPU-Z,
http://www.cpuid.com/softwares/cpu-z/versions-history.html
If you need guidance in downloading, installing, and using CPU-Z, hit me up in a Comment.
Download page for the free Service Manual, for the Toshiba Satellite Pro L300 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down with your eyes to the heading - Satellite Pro
Go across, and click on - L300
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on - L300 - it may take up to 30 seconds before you will see the first page come up.
It may also take additional time for the file to fully download.
Have questions I'm right here.
{Now you know Why, How, and Where.
You can tell your friends about your new found knowledge}
Regards,
joecoolvette
Jul 12, 2011 | Toshiba Satellite Pro L300 Notebook
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
Igxprd32 display driver stop responding is flashed on my computer when i play games on my desktop .what can i do to fix that problem so that i can play games on my desktop
This is a problem with the GM965 chipset display driver. you need to search for the updated display driver for your computer/laptop and then install this to your system.
steps:
  • Right click on 'My Computer' and select 'Properties'
  • In Properties screen, select 'Hardware', and then 'device manager'
  • Look for 'Display Drivers/Adapters', and then look for your display drivers (e.g. Intel(R) GM965 chipset display).
  • Right click on the name of the display driver and choose 'Uninstall'.
  • Reboot your computer.
  • Go to http://www.update.microsoft.com
  • Choose Custom Update option
  • you will see microsoft page checking for updates for your system
  • once it has detected that your display driver is missing or needs to be updated
  • you can click in Hardware link on left side of screen and it will show you the old version of your display driver
  • simply install this one and you are done.
Oct 19, 2010 | Computers & Internet
I have intel GM965 chip for the display and I am trying to play Call of Duty World at War and it wouldn't let me saying video card or driver doesn't support UBYTE4N vertex data.
Simply go here:
http://www.systemrequirementslab.com/referrer/srtest
Select CALL OF DUTY WORLD AT WAR and run that tool.
This will tell you if your hardware is compatible with the game.
if it all looks good (and is marked in green as GOOD) then ensure you have the latest drivers for the devices.
Intel GM965 drivers for XP are here:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17353&lang=eng
Dec 31, 2009 | Microsoft Xbox 360 Console
Magnifer button
http://notebook.driversdown.com/notebook-drivers/IBM-ThinkPad-T60-1951-notebook-Display-driver-(Intel-940GML-945GM-GL960-GM965-950-X3100)-forWindows-XP-2000_70881.shtml
Go here and scroll down a bit and click on
Download DriverScanner to get the most current drivers for your computer
This will update your entire system with factory drivers
Please remember to rate me.
Feb 02, 2009 | IBM ThinkPad T60 Notebook
Presario c700 downgrade to xp no sound driver available.
The C700 USES THE INTEL GM965 CHIPSET.
PENTIUM DUAL-CORE T2XX IS A MEROM BASED (C2D) CHIP.
MEMORY/WIRELESS CARD/AND GM965 CONTROLLER.
GMA X3100 GRAPHICS ARE INTEGRATED.
The drivers can be downloaded here.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3466274
Please rate this solution.
Jan 17, 2009 | Compaq Audio card Sound Card
Wifi ad-hoc for p1i
the SMC adaptr for P1i is 802.11b or 802.11b+802.11g
Jul 18, 2008 | Sony Ericsson P1i
Computers & Internet Logo
95 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
