Hello There, I just brought this used 55inch wide screen Philips projection tv. The color on the screen are faded and bright. the concentrated colours glows too much. The colour clouds are everywhere. sometimes it looks like too much red , and sometimes blue depending on the colour of the picture. I tried to some convergence, i can see the red and green lines clear, but when it comes to blue, its very very light and it always looks like a blue cloud not like a sharp line. I wanna fix it my self rather than spending money on mechanics. Any clues?? If yes can u let me know what store i can get parts from. Thanks in Advance
  • 192 Answers
SOURCE: Tiny blue dots and ablue cloud at the bottom
There is a possibility that the symptoms that you described is covered under an additional warranty, even if your set has been out of warranty for years. Sony has a site that describes this repair at no cost to the consumer: If this is not covered, then, the blue light panel is going out and that means it needs a light engine. Good Luck
Posted on May 13, 2007
  • 934 Answers
SOURCE: colour problem on rear projection tv
This might be something really simple... In a large number of DPTV310 chassis, of which this TV is, the yoke connections where put in place with black electrical tape just below the retaining rings. Job is to loosen the rings, remove the tape and push the yoke back in place and tighten down retainer.. Be careful not to throw off the tilt of the yoke. The adhesive on the tape, over time, gets hot so many time it becomes slippery and allows the yoke to fall away from it's position dulling the look of the image (or focal length) causing the problem you're describing here... It also throws off the convergence - so in attempting to converge it just looks worse. Good Luck Bill
Posted on Jun 11, 2007
  • 5138 Answers
SOURCE: Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Posted on Jan 09, 2008
SOURCE: Philips 50PP920217F remote/color
Whats next after IC's replacing?
Posted on Mar 10, 2008
  • 365 Answers
SOURCE: Projection tv has a red '' aura'' / red blurry spot in the center
i think there may be some dead pixels.try to check it
Posted on Nov 25, 2008
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
Philips big screen hazy/color problems easy fix?
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
  • Halos around objects
You can see some example photos and find a solution here...
Nov 28, 2009 | Televison & Video
That could be either the coolant is needing replacement or the ICs have failed can you post a pic of the screen and I can diagnose correctly
Mar 04, 2009 | Philips 55PW9363 55" Rear Projection...
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture is fuzzy and color seems faded
Sounds like your coolant in the tubes need to be repalced. This is a common problem as the set gets older. Check with for the supplies and instruction guide.
Dec 09, 2008 | Philips 46PP9302 46" Rear Projection...
Philips big screen tv
Oct 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Projection TV - Model 9P5511C
Common problem with the model. Check the site They have a fix for the shrinking and expanding screen problem.
Sep 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
My 50 inch philips projection tv turns on sometimes does not turn on
I just brought a philips 42 flat screen and i was told that it had
a 2 pixel wide line going down the right center of the tv.
is this bad and or can this be fixed. Thanks!
Nov 23, 2007 | Televison & Video
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
