Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
Moniter flashes off
When I turn my computer on, My MAG 19' monitor (about 2 1/2 years old) somes on for MAYBE a second and goes black. When I turn the monitor off then back on, it comes on for a SECOND and black again. I can click on something right away and when I turn it on again, the same or new screen is up...so it is getting feed from the tower, it just will not stay on. I am on a frineds computer right now as I cannot see my screen long enough to do anything. I am not sure i entered the correct/ product as I am not at home.
  • 4 Answers
A lot of times this is caused by bad caps on the power board, at least with certain other brands. Mine did this when I got it as a DOA donation. If another monitor works fine on your PC as suggested, it would be worth your time to open up the back and check for any capacitors that are swollen on the top or bottom or leaking (worse). If you don't want the hassle of replacing these or are unsure of how to solder/desolder, please don't just throw it away... they are filled with mercury vapour and should be disposed of properly, or FIXED. There ought to be someone local who knows how to do this... if not, hit me up.
Posted on Jan 10, 2009
    Scholar:
  • 147 Answers
It may be sensing a sync or timing problem. If you've recently changed your resolution, (or if a virus did that for you), the monitor might not like it, and will turn itself off to protect itself from over-clocking on a mode it can't handle.
Try booting in safe mode, and see if the monitor cooperates. If so, you can then change the resolution to something a little lower, in hopes that it is supported.
Try borrowing a monitor - if the borrowed one has the same problem on your pc, it might be a problem with the video card instead.
Posted on Sep 16, 2008
Black moniter
It has power problem...
Apr 10, 2014 | Neovo F-419 19" LCD Monitor
I have a mag lt 2219 and everytine I turn it on it goes black
moz-screenshot.jpgHello Chris,
You have a monitor with a common problem. After a few years some LCD monitors will blown a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, iff so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 18, 2009 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag Innovision LT917s 19 inch monitor- On and Off !!
Replace it.  It would probably cost more to get it repaired.
May 28, 2009 | Mag Innovision LT917S 19 inch Monitor
Moniter very lightly flashing
Problem was not solved. I am returning to Samsung. Thanks.
Jan 05, 2009 | X2Gen MG19MY 19" LCD Monitor
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
MAGinnovation LT916s
Hi...there,
It's seems you need to replaced a new backlight inverter. Check this site out...@ www.3rd-rocks.com
maybe have what you needed... Have a nice day!
Jul 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Lcd monitor goes black after 5 seconds
I have read it may be an inverter. Anyone know what that is or where I can get one for the mag lcd moniter lt1919wdb?
Mar 29, 2008 | Relisys RLT1720 17" LCD Monitor
MAG Innovision LT916S monitor problem
Hi this is the way how to examine what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Mar 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
19 in lcd mag monitor
You need to try another monitor, any type. If you find another monitor does functions return the 19" monitor. Most monitors come with a 1 year warranty.
Feb 12, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
Computers & Internet Logo
192 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
