Question about Barracuda Networks Barracuda Web Filter 410 - firewall Rack-mountable (BYF410A3)
Unit will not resolve DNS
I setup the webfilter. It runs through a Sonicwall firewall. The unit works just fine when its set to a non-active monitoring mode - I can see all traffic in the log... The moment I set it to active, no one can resolve DNS. I have tried internal DNS, External Servers and pointing to the firewall and no luck. I have put in static routes pointing to the internal DNS and a blanket route for all IPs and nothing. I have tried with transparent mode off and on and still same issue. Anyone have any ideas?
    Scholar:
  • 109 Answers
Ditch the Barracuda and use the SonicWall Content Filtering option, it's cheaper anyhow.
Barring that, reset it to default, and make sure that it is using the SonicWall as its gateway, along with the proper DNS settings. Also, check for a firmware upgrade on the unit. I've run into a few Barracudas that have nothign in the knowledge base but a firmware upgrade fixes them.
Posted on Dec 24, 2009
I am a admin at a new company and they do not know nor can they find the Admin login and password. Is there a way to hack in to the SonicWALL PRO 230 Firewall unit?
Deafault user: admin
password: password
default ip: 192.168.168.168
if in case you cannot get in, you need to reset the device to its factory default.
thanks
eric
Oct 29, 2010 | SonicWALL PRO 230 Firewall
Windows 2003 SBS Standard Edition ? IP Address: 192.168.1.5 Linksys WRV210 ? 192.168.1.1 Screenshot Router setup page: http://img205.imageshack.us/img205/3889/capture1w.jpg I have setup a preferred...
hello, is your server 2003 setup as DNS server??? if so have you configured forwarder for non- local access? is that a home? or business? is it work do you not have a static public IP address.
here whats happening, when you manually give client the DNS they can resolve everything local fine but when a request for outside world is sent your server doesn't know what to do with it. log on to server open up your dns console, right click on your domain, then select properties, find forwarder tab and add a any reliable public DNS server there ( ie I use 4.2.2.1 (att)) server pretty quick and reliable.
so next time a request is sent to your server and server doesn't have that information it forward that to the public DNS and you will be good to go.
but from your setup i am gathering there is plently you do to improve your network and reduce your headache of manual work.
typical setup: 1- setup DNS with forwarder
2- Setup DHCP on Server instead of router ( trust me its easier than you think)
3- put all setting to for clients in DHCP options
4- reserve IPs for servers/prineters/switches etc.
5- set all clients for DHCP
6-disable DHCP on router.
let me know if your need help setting it up.
i hope this helps
good luck
Amar Sondhi
Dec 07, 2009 | Computers & Internet
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Google site problem in Network
check in your firewall security settings.
that blook gmail .
Nov 29, 2008 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
I want to create site to site vpn with sonicwall tz170+ 2003serv
Complete documentation is available on the below link
http://www.sonicwall.com/us/support/3134.html#heading_3139
Nov 17, 2008 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Sonicwall Internet Connection Issue! HELP PLEASE!!!
juz clear the arp entries or else change the connectivity cable from modem to firewall.
Aug 21, 2008 | SonicWALL PRO 230 Firewall
How to configure Sonicwall TZ 190? I have connected console to the Sonicwall and trying to open it via Console. But no configuration or prompt is coming. Kindly help ASAP.
open control panel and then add printers and other hardware, then up in left hand menu go to system then hardware, device managed and check if your driver is updated. if it says it's working properly then uninstall it and it'll pop back up reinstall then it should work fine.
Dec 03, 2007 | SonicWALL TZ170 (01-ssc-5740) Firewall
Can not connect to PPPOE DSL
Is there a reason why the Sonicwall needs to do the PPPOE auth? You should be able to let the modem do the PPPOE connection and have the Sonicwall behind it. The Sonic wall will get a private IP address. Andy
Jun 21, 2007 | SonicWALL TELE2 Firewall
Site to Site VPN Link with dynamic dns
Hi Rajmeet, Here is the documentation on the SOnicwall TZ170 the detail configuration can be found on page 211. Please let me know if this helps you and if youhave any other questions. http://www.sonicwall.com/downloads/SonicWALL_SonicOS_Standard_3.1_Administrators_Guide.pdf
Apr 02, 2007 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Barracuda Networks Barracuda Web Filter 410 - firewall Rack-mountable (BYF410A3) Logo
585 people viewed this question
Top Barracuda Networks Computers & Internet Experts
David Payne
David Payne
Are you a Barracuda Networks Computer and Internet Expert? Answer questions, earn points and help others
