Question about Kenmore Elite 45986 Front Load Washer
Flashing code f01
Water was leaking out front of washer had to stop and now code f01 is flashing -clothers are still sitting in water. How do we fix this?
  • Anonymous Mar 05, 2009
    Kenmore front load washer F01 flashing. Read about 15 different things to try including the unplug, diagnostics test,. This is what I came up with minimal skill level for me. Took the kicker plate off at the bottom.
    Took the waste pump off (very easy once you learn the trick) Cleaned out trap and also garbage in the pump itself There was a lot of garbage inside the magnetic shaft that needed to be clean messy. Put it all back together 15 minutes total. Didn't work; Took the top lid off only 3 screws on the back. Check all wires to the M/B Top front right side Took the other end of the screw driver and lightly hit the cover to the M/B just to shake things around a little Pushed the start buttom and its been working all night long. Thanks to FIXYA bloggs.
I have Minimal skill level. But read many bloggs. Take the waste pump off; seriously not hard. Clean out the trap and also the magnetic shaft section in the motor. It rotates about 3/8" and pops off. I had all kinds of gue in the rotating shaft section water must have passed by the o ring.
I took off the top cover and found the mother brd. Hand checked all wires then I took the handle end of the screw driver and lightly hit the cover of the M/B to shake things up a little. Pushed the start button and its been working all night. Seriously if that fails get online and order the M/B it didn't look that hard to unplug some wires and replace. Thats the same as a technician would do. I learned that from my high dollar fridge with a bad ice maker $250 dollars latter 15 minute board swap. Thats why I tried on this one to do it myself.
Thanks!
Posted on Mar 05, 2009
    Genius:
  • 1,028 Answers
F01 is usually control bd failure but first try removing power to washer hold start button or almost any button will work for 10-20 sec reconnect power and try again if still codes f01 suspect main control bd top rear of washer
Posted on Sep 16, 2008
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
My Kenmore He2 at the end of wash my clothes are still heavy with water and a f01 code is flashing
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing then it beeps and H and F flash, washing machine stops and only the flashing H and F appears..............
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter sits right in front of the water inlet valve and is attached via a hose and is off to the left side of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this error code. Sure hope this helped and best wishes.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Duet washing machine
f-11 is a motor control unit error.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F01 Error code
most likely suspect main control bd
Apr 11, 2008 | Kenmore 46462 Front Load Washer
F01 CODE
I don't remember what code my washer was flashing.....but, when the service guy came out he opened the bottom panel and pulled out a service guide and he emptied out a trap and my washer has a button, small eraser in there that I guess clogged it up......so, ?
Nov 17, 2007 | Kenmore Elite 45986 Front Load Washer
Error Code F01
F01 is not a valid fault code but if it is displaying that and all the lights are flashing the main computer has gone haywire. Possibly the display board (in the plastic panel that houses the buttons) may be faulty but this is unlikely
Sep 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
90 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
