Put new ink cartridge and can't install - Office Equipment & Supplies
  • 1 more comment
  • renetta mason Feb 27, 2009
    I'm getting very frustrated!! help me please!!!I'm listening to your suggestions and still nothing this is a knew printer I can't believe this.I changed the ink replaced it,still says when I check the ink level still says low and test page still incomplete,and where is the "OPTION" button to tell it that I changed the ink??????
  • Anonymous Mar 06, 2009
    Printer keeps telling me cartridge is missing and that I should install it when it is right in there.  Also seems to be the Cyan cartridge everytime
  • ReneeHK May 26, 2009
    When I put in a new black cartridge the printer message window is telling me that the cartridge is incorrect. I have taken it out and reinstalled it a dozen times and keep geting the same message. What do I do now?
    Scholar:
  • 148 Answers
Replacing your cartridge:
  1. Make sure the printer is switched on.
  2. Pull the operator panel forward and open the cartridge access door. (Note: The cartridge carrier moves to the loading position, unless the printer is busy).
  3. Pull the old cartridge forward and then lift it out.
  4. If the cartridge is new, remove only the sticker or transparent tape on the bottom of the Cartridge.
  5. Insert the cartridges into the carrier and push back firmly until they snap securely into place.
  6. Close the cartridge access door and the operator panel.
  7. From the operator panel, press Options to select the cartridges that were changed.
  8. Press Start (Start/Yes), Options to select the cartridge type installed.
  9. Press Start (Start/Yes).
Posted on Sep 16, 2008
I just refilled my black cartridge thsi morning at office max. i installed it in my printer. the alginment page keeps printing and nothing else. i did remove the protective tape on the print cartifdge like the problem said. but it still keeps pringitn aligment page...it a dell photo a10 printer 924. this is my first time to intall an ink artridge. what am i doing wrong......
Posted on Jan 24, 2009
IB4G2008
  • 3587 Answers
SOURCE: INK CARTRIDGES
turn off printer...check the bottom of the printer cartridge for any blockage or film
Posted on Apr 24, 2008
  • 65 Answers
SOURCE: new ink cartridge not working properly
if you open the lid of the printer you should have the ink slide to have you take it out.
I would unplug the printer for about 5min and then plug it back in and then it should ask you to redo it again.
Nikki2913
Posted on Dec 02, 2008
bravsman
  • 94 Answers
SOURCE: After putting in new ink cartridges how do I align them?
click start start botton go to settings click printer and faxes and right click to your printer cannon mx310 go to properties click maintenance
Posted on May 25, 2009
  • 10865 Answers
SOURCE: new cartridges won't install.
unplug your printer. then remove the cartridges and reinstall them being sure to seat each one firmly into it's socket. finally plug the printer back in.
Posted on Aug 17, 2009
xptareq2000
  • 1447 Answers
SOURCE: i put new ink cartridge and is not printing
clean cartridge if you are not active print docoments then change printer head
Posted on Nov 22, 2009
I just put in new ink cartridges. It scans fine but will not print from my computer
Hi Karen:
If it worked before you installed this cartridge, there are 3 possibles that I would check.
1) The new cartridge is defective
2) The new cartridge is not installed correctly
3) The pull tab that covers the ink ports was not removed before the cartridge was installed.
Dec 27, 2015 | Office Equipment & Supplies
How do i reset ink cartridge cl511for my canon ip2700
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
Sep 20, 2011 | Canon Office Equipment & Supplies
Our printer countinues to flash E 1 4, even after we have put new ink cartridges. What does this error mean?
This is usually an incorrect installation of the ink cartridge. Take it out and check to make sure nothing is blocking the way of installing the cartridge, like any packing material or clear tape that might block the connection on the ink cartridge. Reinstall ink cartridge and see if that works.
Mar 02, 2011 | Canon Office Equipment & Supplies
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart 3310 Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Reinstalling ink
I put a new magenta cartridge in the printer. It says to open the scanner cover, then reinstall ink cartridge. when i open the scanner cover nothing happens and i dont know how to install the ink.
Oct 03, 2008 | Brother DCP 115C All-In-One InkJet Printer
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5300 will not accept the new ink cartridges
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
977 people viewed this question
jasbo
jasbo
