Take a look at this and see if it helps
https://discussions.apple.com/docs/DOC-6271
SOURCE: unable to work on oki c5500n on dell x64
If you are using this printer w/ two different versions on it or if it is on a network you must install both drivers. Your printer has its own web id if it is hooked up to a network. You can go into devices on network, right click on the printer and go to device web page. The problem is you had it working w/ a more advance version and now you are reverting operating systems.
SOURCE: My Oki C5150 is not recognized by Snow Leopard.
I had same issue...I called OKI 800 number and they walked me thru it - no problems at all now.
SOURCE: reset drum life on oki c5500n
try this:
1) Power on printer while holding both the + & - buttons simultaneously; release when "Okiuser" is displayed.
2) Press + or - until "Engine Diag" Mode is displayed; press Enter and Diagnostic Mode xx.xx.xx will be displayed
3) Press and hold both Enter & On-line simultaneously until Eng Diag Level3 is displayed
4) Press + or - until Local Parameter Set is displayed; release and press Enter
5) Press + or - until it displays Factory Mode; if it displays Factory Mode Twice with an asterisk next to one then it is in Factory Mode; Press Enter, Press + or - until it displays Factory Mode & Shipping Mode on the display; then press and hold On-line & Cancel simultaneously; when it stops blinking an asterisk should be displayed next to Shipping Mode, which becomes the default mode.
6) Power printer off then on to complete the procedure.
SOURCE: I upgraded my macbook pro
Unfortunately the latest driver for your OKi printer is not compatibile with Mac OS X 10.7 Lion. Okidata sent out an official announcement (OKI Printer Driver Compatibility with Mac OS X Lion - Revision 1.6) which details expected release dates for various printers.
