Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu v2010 keyboard problem
Hi i have a v2010, that has generated a problem, firstly the keyboard is in german format, but even though im trying to get it communicate back to the screen its missing some keys when pressed, and others is responding in a different manner than the key should display on screen.
any ideas would be great!
thanks
alan
  • bigal123uk Sep 17, 2008
    i have tried a usb keyboard but the same problem applies,i was usure if there was a setting that may be needeing change
    thanks
  • EDDIECOTE May 11, 2010
    You may try a Linux live CD (Ubuntu, Knoppix, Kubuntu... they are downloadable for free) to isolate the problem from your Operating System. If it keeps working wrong... it seems a hardware failure.
    Also if i were you I would try an external keyboard to compare its behaviour with the integrated one, so you will have more info about the problem.
Product key on new fijitsu wont work
tell this to fujitsu ur key is leaked they will give u new key
May 24, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I need a new fujitsu siemens amilo ms2212 keyboard. anybody knows where can I to buy one these?
I would check on eBay and do a web search with as many params as possible, such as:
Adding the keyboard part number to above would narrow the results even better
Apr 05, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Keyboard replacement instructions for fujitsu siemens amilo pro v2010
The keyboard removal process is very similar to many other laptop brands.
1. Remove screws securing the keyboard.
2. Remove keyboard bezel.
3. Unplug keyboard cable from the connector on the motherboard.
A word of caution. Be very careful with the connector on the motherboard when you unlock it If you accidentally break the connector, you’ll have to replace the whole motherboard.
You can even try this site http://mycapsules.com/disassembly/fujitsu-s2110/keyboard
or this site
http://www.amilo-forum.de/topic,1056,-Arbeitsspeicherwechsel-RAM-bei-Amilo-Pro-v2010.html
It is not your model but it will give you an idea.Just keep pressing "next"
Hope it helped.
Aug 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Wifi connectivity
Yes it is. Ensure the Wireless Lan switch is on (button at top right above keyboard) which will light an indicator on the light panel).
Got this info by downloading the manual from here:
http://uk.ts.fujitsu.com/support/manuals.html
May 15, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
We droped coffe over the keyboard most keys work but some dont
Wait for a couple of days to see if the functionality comes back. You will probably need to replace the keyboard though. They aren't too expensive - maybe $60-$80 (USD).
Let me know if you have any other questions.
Jan 28, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Memory uprgrade
You have to remove the keyboard, under the keyboard to the left is a heat shield (silver metal cover), remove it. Your ram is located there. Just take your time and remember where the screws go.
Jan 22, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Power pin
I've found instructions with a diagram about how to open it up (for a memory upgrade). The directions are in German, but the pictures should still be useful.
Basically, the directions
1. Shutdown the laptop, turn offthe main source on the wall, unplug and
disconnect the power supply fromthe laptop.
2. Discharge yourself by touchingthe unpainted part of a PC or a radiator.
3. Remove the battery from thelaptop. (Shift the battery lock and pull
battery pack out.)
4. Remove the control Panel (usea razor or a flat butter knife ) push the
knife downward gentle and tilt itabout 30
o
outward to release clips and
left panel. Repeat the process onthe other side till the entire panel is
freely removed
5. Remove the panel to expose thesingle screw that secures the keyboard.
6. undo the screw to free thekeyboard and lift the Keyboard gently
7. Undo the clip that holds thekeyboard connector Ribbon in place this
would completely free thekeyboard. Remove the Keyboard. To unveil a
metal plate
Nov 10, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Wireless drivers??
download Ralink Wireless adapter and install it...check it out
Sep 26, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
262 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
