Question about Pioneer Televison & Video
Pioneer error incorrect disc c104. it play a day ago what happen
5 Suggested Answers
SOURCE: DVD recording or playing.
You will need to purchase a DVD that is 1-2X. Only way I could get mine to work?
Posted on Jul 15, 2007
Where can you find the 1-2X DVD, I have only been able to find 1-4X and none of these work.
Posted on Oct 16, 2008
SOURCE: solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
Posted on May 19, 2009
  • 14 Answers
SOURCE: does not read disc
try cleaning the disc
Posted on Oct 24, 2009
satavlad
  • 405 Answers
SOURCE: ERROR H02
Spindle motor in DVD mechanism require replacement, not practical to repair, just buy new one, upconverting DVD player would cost you less then repair of your old one.
Posted on Dec 01, 2009
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
Sansui dvd recorder gives an error code c206 and a c104 when i try to record.. sounds like a common problem
C206 caanot create TOC " table of contents" C104 coul;d not finalize session.
These are all signs of the laser at it prime or the laser veryy dirty. you may want to try cleaning it first, if that does not work then repair or replacment of the unit as a whole. this brad in genral only last 1 year until the go out or reqire service.
sure hope this was Very helpful, please do leave some positive feedback and ratings for your free answer today.
May 03, 2010 | Sansui VRDVD4005 DVD Player/VCR
I have a Sansui model VRDVD4005. When I put a DVD
I think you need to take it to the service center, because there's nothing that you can do all by your self.The problems starts from the optical lens/ laser pick up, replacing the lens could be necessary.
Mar 07, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Cannot record on Sansui VRDVD4005
Usually this would signal a bad disc, but if the discs have been known to be good, then your lens may be failing.
May 14, 2009 | Televison & Video
Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Dec 27, 2008 | Sansui VRDVD4005 DVD Player/VCR
C104 disc read error suddenly and constantly on all commerceial dvd movie discs
This means the Country Code is not the same on the disk as the DVD player is coded for. Sometimes this can be corrected by unplugging the player for a couple of hours or if it has a reset button press that.
May 24, 2008 | Pioneer Televison & Video
Feb 07, 2007 | Sansui VRDVD4005 DVD Player/VCR
Televison & Video Logo
276 people viewed this question
Top Pioneer Televison & Video Experts
Electro Med Services...
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
