ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
I own an Acer 9410-4933 that when I try to install 4Gb of Crucial RAM ( 2 – 2Gb chips ) wont boot up. Here’s the RAM -
Here’s the LAPTOP RAM specs –
Memory Technology
Maximum Memory
4 GB
Installed Memory
1 GB
ALL SPECS-,44731581-sortby,retailer/specs.html
It has 2 slots, I can boot with EITHER chip in EITHER slot or 1 – 2Gb chip and 1 – of my old 512Mb sticks for a total of 2.5Gb but if I put both in the BIOS says 3Gb and the laptop just goes to a blank screen and does nothing.
Any suggestions??
  • Anonymous Mar 24, 2014
    is it possible to put in 3 gb ram on asus f5r laptop series ?
The 2 – 2Gb chips are BOTH PC2-5300 memory module.... Why do you say THEY DO NOT MATCH??
Posted on Sep 17, 2008
  • 68 Answers
Posted on Sep 16, 2008
Want to increase speed
You can upgrade the RAM providing you have the slots available.
The maximum supported RAM in windows 7 is 4GB. You will find the serial number on the bottom of the laptop, possibly in the battery bay. You can use the following scanner to check the required RAM.
Jan 20, 2013 | Acer Extensa 4230 Notebook
What kind of motherboard is in my acer aspire AST 180-UA381B- It has 4 RAM slots and when i tried to add the 3rd it whent nuts with beeps
The motherboard for the Acer Aspire t180-UA381B desktop computer, is supposed to be based on the Foxconn AM2 MCP61S series of motherboards.
Based on one of these two with some small modifications,
(You can click on Specifications for each motherboard, then click on the photo of the motherboard to enlarge.
After clicking it takes a second, then a small window comes up on the left. Click on the Maximize icon. { Icon to the left of the Red X)
There are Four ram memory slots.
2 of the ram memory slots make up one Channel.
The other 2 ram memory slots make up the other Channel.
When you use ram memory that has the SAME specifications, in the SAME channel, you are using the ram memory in Dual Channel.
[ And I mean the SAME.
Sometimes this means from the same manufacturer.
Same type, same frequency rate, {'Speed'}, same density, same chip configuration, same ram timings, same voltage, Unbuffered, and Non-ECC ]
When you install ram memory in a Dual Channel configuration, the two ram memory modules ('Sticks'), 'piggyback' off of each other.
They essentially team up on the task.
In the past this was thought to increase ram memory 'power' up to 30 percent.
Extensive testing has proven this to be a fallacy.
2 to 3 percent is more accurate.
The Maximum Total Amount for the motherboard, (Relying, if it does indeed follow the specs of the Foxconn motherboards linked above), is 4GB.
[ According to Acer Support, the above criteria follows suit, ]
EACH ram slot's Maximum Amount is 1GB.
If, perse, you have 1GB in each of the first 2 ram slots that are closest to the Processor, (Same channel. Same color), and are trying to install a ram memory module of 2 GB in the 3rd slot, this isn't going to work.
If you are trying to install a ram memory module that is of a different frequency rate ('Speed'), it may also not work.
Example: DDR2 Sdram at 667Mhz, (PC2-5300), and DDR2 Sdram at 1066MHz, (PC2-8500)
Further example:
You have 2 sticks of PC2-5300 at a 1GB amount in Slots 1 and 2.
You try to install a stick of PC2-6400, or PC2-8500 of 1GB in Slot 3.
Not happening.
BIOS will try to clock down the faster ram memory to the slower ram memory that is installed.
One step up, (PC2-5300 to PC2-6400 for example), may work.
Two steps up will not.
(Example PC2-5300 to PC2-8500)
It also depends on what Processor you have installed.
Ram memory typically operates at half of the FSB frequency rate, that the Processor's FSB does.
According to Acer Support, an AMD Athlon 64 X2 processor, or an AMD Athlon 64 processor, or an AMD Sempron processor can be installed.
I suggest using CPU-Z from, and find out the exact specs of the hardware inside your computer. (It's free, although they do accept donations}
As stated, Crucial has a good system scan analyzer, but has been found to be unreliable, or doesn't work in some circumstances.
You also need to know the specifications of the ram memory you are installing.
Comparing stock performance ram memory, to high performance ram memory.
Some of the high performance ram memory uses a higher voltage, for one.
For two the ram timings are different.
For three the density of the DRAM chips are different.
For four the Chip Configuration is different.
Just some of the parameters that can vary.
Stock voltage for DDR2 Sdram set by JEDEC at 1.8 Volts.
This is what is set as a default voltage in your computer, for your ram memory.
Use high performance ram memory that may use 2.1 volts, and there's going to be a problem.
Also if you purchased this ram memory from Ebay, good luck.
Need to know WHAT ram memory you have installed in Slot 1 and 2.
Give me any numbers off of the ram memory module that you see, and if there is a manufacturer name.
Same with the ram memory module you are trying to install.
Also would like to know if the two Foxconn mobos, (MOtherBOard), that I linked above, resemble yours.
Post in a Comment.
Aug 14, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
Max supported memory on acer aspire 5672?
This laptop can support up to 4 GB or RAM.
May 08, 2010 | Acer Aspire 5672WLMi Notebook
4gb of ram
Go to Crucial Memory's site and run the "scan my system" option. It will tell you the exact amount of memory your computer supports, how many slots are empty and what is in the occupied slots. The link is
Feb 04, 2010 | Acer Extensa 5620-4020 Notebook
Acer laptop 2310 series, 5yrs old 40 GB HDD; 256 MB DDR.Windows XP. Can i add more memory & if so how much?
Yes you can. You can increase the memory up to 1GB. If you are going to keep the memory inside then you should buy a 512 MB memory card, making your computer run on 768 MB of memory. If not then replace it with a 1 GB memory card. Remember, this computer can only support a maximum of 1GB total memory. The price depends on the memory module. The higher it is, the higher the price will be. Go to your local computer store for the price.
Dec 19, 2009 | Acer TravelMate 2300 Notebook
Hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
Aug 20, 2009 | Acer Aspire 5315 Notebook
Acer 5610 memory capacity?
This laptop only has a MAX support of 2 GIG of RAM so you wont be able to upgrade it to 4 GIG or RAM....
Jun 16, 2009 | Acer Aspire 5610-4491 Notebook
Hi there.
The memory slots are more or less on top of each other.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Acer Aspire 4315 Notebook
Boot with over 2GB of ram
Make sure you got the right speed -
Each memory slot can hold DDR2 PC2-4200 or DDR2 PC2-5300.
If you got faster than 5300 they may not clock down properly.
If the memory is the correct specs then it may simply not be compatible and you will have to try different RAM.
I have the best luck on laptops with Crucial ram - they have certified ram for many systems. here is a link for yours:
Dec 27, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
605 people viewed this question
David Payne
David Payne
