Question about Nokia N73 Cellular Phone
N73 problem dear friends, in my nokia n73 when i press a button for once it works like twice or more. for example, i need to dial 017 and i press on a 0 it appears 00 or 000. my phone buttons are harder than other's. why its happening and what should i do please tell me..
    Scholar:
  • 148 Answers
Change the phone keypad, it could be not really fitted into the phone.
Posted on Sep 16, 2008
My nokia n73 is very slow. i want to format it's phone memory. when i press code it ask for lockcode..i gave 12345 and 00000 but it didn't accept....wat should i do?? plz help
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone
1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number '3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
Jan 24, 2011 | Nokia N73 Cellular Phone
Tip
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
on Aug 06, 2010 | Cell Phones
My N73 shows a message like this"phone memory is full" but i have deleted ALL of my datas in phone memory, i really dont know what else should i do!!!
Hello
You might have to format your phone memory.
Unlock your Nokia N73's keypad by pressing the left soft key found just above the green call button and then pressing the "*" or asterisk key.
Press a series of five keys on your keypad following the sequence "*7370#" without quotes. Assume that you are dialing this as a number. The N73 should show a confirmation message right after you press the "#" key.
Read the Warnings section before proceeding and choose the "Yes" option from the confirmation message to tell the Nokia N73 to format the phone memory.
Oct 04, 2010 | Nokia N73 Cellular Phone
I want to format my n73 how can i do
here is how to format Nokia N73
1: Turn of the phone
2: Press and hold the green dial button +* + 3 and then power on the without releasing the buttons until it turned on. It will give you a time option after.
Note: Don't release the buttons until it completely on because it won't display the formatting message.
Sep 12, 2010 | Nokia N73 Cellular Phone
L forgot lock code
You will need to format the phone.
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key.
4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone
5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting.
May 17, 2010 | Nokia N73 Cellular Phone
Hard formating of nokia n73 mobile by pressing "green", "*", "3" buttons while starting is not working
ok pls try this when ur mobile is on dial code like this
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
Pls rate me WELL or ask for more help if not solved !
May 18, 2009 | Nokia N73 Cellular Phone
My n73 works slow and I cannot find a suitable dictionary to install in it .Ps help
hii actully u have to gin=ve some technical touch to ur n-73 follow the process
1 For slow working of it just formatt ur phon once by removing the memory card (remove mmc & sim)
2 swicth off the phon for 3-4min
3 now switch on the phone by pressing STAR(*), 3 and green button (DIAL button)
by this ur phone will formatt
then .............format ur mmc (u can make back up if u need ) simply then after again loading the data on ur mmc put it on ur phon and switch it off for 5 min ur phon will be hang free and smooth working
if u still feel problm contact me again
IF PROBLM SOLVES PLZ VOTE ME
Apr 26, 2009 | Nokia N73 Cellular Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
N73
ON THE WRITE MESSAGE PRESS # TWICE..
Sep 16, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
