Question about Power Acoustik 7 Widescreen Headrest Monitor"
Wiring problem i purchased 2 used 5.6 power acoustik LCD monitors apparently the seller left the wiring that goes to the dvd player in his car that was wreck how can i hook these two monitors to my player without the exsisting wiring
  • 397 Answers
DO YOU HAVE THE PRODUCT # FOR THE MONITORS, I CAN PROBALY FIGURE SOMETHING OUT IF YOU CAN EITHER GET THAT OR SEND ME A PIC OF THE CONNECTION......COOL
Posted on Sep 17, 2008
The monitors are made by power acoustik there is a green wire a red wire and the white wire has a wire in the middle surrounded by ground wirewiring problem - 8a804da.jpg
Parking brake switch wire on a power acoustik double din
this use to be simple for most units and yes it would work, however, manufactures became wise to this idea and placed a relay inside the unit that must be reset to prevent us WISEGUYS from doing so, but i do not know if this is the case with yours, if it is then you can run a toggle switch between the unit and the ground in order to reset this relay as needed with a flip of the switch
Feb 21, 2013 | Power Acoustik PTID-6250 6.2" DOUBLE-DIN...
How to hook up the ground wire the red wire and yellow wire
Usually, wiring schematics or color codes are universal. try these simple color codes:
Red - Positive line (+) - to battery or capacitor
Black - ground (-) - must be attached to the body of the vehicle
Yellow - Ignition switch line
Other white-lined wires paired with solid colored ones are usually for front and rear speakers.
There might also be 2 wires that is labeled "LINE OUT" which goes to the LINE IN of your Power Amplifier.
Dec 09, 2010 | Power Acoustik PTID-8001N Car DVD Player
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Jan 24, 2009 | Power Acoustik PTID-5300 Car DVD Player
Power Acoustik PMD-83CM
the spindal on the motor could be bad, could have bad transverse motor or even a bad laser., had to say with out seeing it do it.
Dec 03, 2007 | Power Acoustik 8 Monitor With Dvd Car...
WIRING
You need to order extra components in order to use the optional GPS function.. you can try checking circuit city or the Authorized Acoustik Suppliers for the products like the websites or you can check Ebay as someone might have the product
Nov 18, 2007 | Power Acoustik LT-980/2 Car Audio...
Not On List - Power Acoustik PADVD350
to answer #2: go to radio shack and purchase an ignition power filter. This is wired to the power input side of the unit to eliminate ignition noise. ...but not sure about remote...it should not be a wire problem...try removing batteries of remote and re-inserting to "polish" the contacts.
Jun 08, 2007 | Power Acoustik PACD-825R CD Player
Power Acoustik 7 Widescreen Headrest Monitor" Logo
443 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
