Question about Astar Televison & Video
Can not get the image back on my astar hdtv when I choose the option
Stuck on the blue screen when I turn the television on. Can not seem to access the image option on the menu. Tried to reset to the factory setting, but it still did not correct the problem. What am I doing wrong? Please help!T hank you!
  • 10,594 Answers
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Posted on Sep 16, 2008
Astar lcd 32" is acting strange. All screens are
Hello, just call me at 323-868-3303 and I will go through with your Astar tv. or you can email me at
Thanks and good-luck 2 you.
Apr 03, 2011 | Astar LTV-3201 32 in. LCD Television
No Picture or Sound from ASTAR 32 inch LCD Television
There is Part Store having Astar LTV-27BG boards in stock. Please check out might help you to power up back your TV.
Aug 28, 2008 | Astar LTV-3201 32 in. LCD Television
My Astar 32" HDTV flat
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.
Dec 11, 2010 | Astar LTV-3201 32 in. LCD Television
Tv will turn on(green on light showing) but no picture. was giving us problem for 1 day with 'invalid input' flashing then blue screen all connections are tight.
Power supply board just die.It can be dead at anytimes.Tries websites, to buy a refurbish power supply board for the replacement.
Hope it help
Jun 01, 2010 | Astar LTV-40HBG 40 in. LCD HDTV
Screen not working
The backlight or power supply for it has failed. Use a strong light next to the screen and look for a faint picture. If it is out of warranty, take it to a repair shop.
Apr 07, 2010 | Astar LTV-32ASB 32 in. LCD Television
There is a green tint to my screen. Seems to be more evident in dark shows and on shadows.
Pull the front speaker grille off and remove the access panel. In the customer menu turn the color off so you have a black and white picture. get a flashlight and adjust the screen controls for the red, green and blue tubes until you get a nice black and white picture. then turn the color back up.
May 26, 2009 | Hitachi 51F59 51" HDTV Projection...
Image green tinted.
May 15, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
32"ASTAR problem
Please call 323-767-6030 and I will trying to help you as much as I can for the astar ltv-3201 tv.
Jan 30, 2009 | Astar LTV-3201 32 in. LCD Television
Only getting a blue screen
Your remote should have a menu button, four arrow buttons, and a enter button. I you press the menu button it should give you a screen with a number of images across the top. The left and right buttons should move you to different areas. There should be one option that gives you the TV move. Use up and down to select the line which allows you to change from cable to broadcast.
Aug 02, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar flat screen monitor
i need help getting my astar flat screen tv to power on. the blue light is on in the center of the tv
Dec 24, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Televison & Video Logo
241 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
