Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wireless Keypad I have purchased a new home and am unable to get a pin or code for the wireless keypad. Could you please advise me how to re-program the wireless pad. I have 1 hand held opener and the button in the garage. We only have one remote which works fine ... so we never had the need to use the keypad while wanting to test it we don't remember the code and we don't know how to reset or reprogramm it any advice ...
    Scholar:
  • 148 Answers
Resetting the Right push button back to Security+ as follows:
Push and hold both buttons for ten seconds or until the yellow indicator light on the back stops blinking. The remote has been defaulted to one of six randomly reprogrammed Security+ settings.
Posted on Sep 16, 2008
I am trying to enter a new code on my outside garage door opener keypad, however, it does not have an enter button, what do I do after I already erased the old code. thanks
If your keypad is hardwired do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Aug 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have programmed a new pin, but the old pin still works. How do I get rid of the old pin? Have tried multiple times and the new pin works, but so does the old one.
If you hold the smart/learn button in for 6 seconds it will erase all the codes from memory and then program the keypad. Just remember before you start that none of your other remotes will work and you will have to program them.
Aug 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears (Chamberlain) Liftmaster. I had to buy a new remote transmitter and it learned the code from the motor. However, now, the keypad transmitter won't work. I have done all the...
Make sure you are using the correct procedure to program the keypad.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Nov 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Purchased a house in short sale with a lift master 1/2 hp model #1155-4 date 11/92. We got a new car remote, it works fine, but don't know how to program the wireless keypad. It is not hard wired and has...
Sorry that keypad is no used to u.If u don't know the secret codes.Just push in the codes it will work.No enter button,mean u just don't push enter after u push in the codes.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman key pad is about 20 years old. Need to re-program code. I know you hit a few numbers then the 4 digit code but I can't remember the #'s.
If it is a wireless keypad do this:
If it is hardwired do this:
Oct 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My wireless keypad stopped working. I replaced the battery. It worked 1x and hasn't worked since. I'm able to program remotes. The keypad is backlit and flashes when I enter the code or try to program it....
I would make sure the battery contacts are clean and not corroded. Otherwise a new keypad is most likely the answer. Just FYI the keypad will still work when the wall control is locked.
Sep 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need operating manual
http://www.paradox.com/Documentation/Manuals/ARCHIVES_UserQuick/SPEKEU-03.PDF
See if that helps. Let me know if you need a new panel/keypad. I have DSC 1616 Power series.
Stewart
May 30, 2010 | GE Security Simon 3 Wireless Home Security...
How do I program a Craftsman Wireless keypad for Chamberlain garage door opener? I purchased the home and the former owner does not remember the code.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this button and then walk over to your keypad and key in any 4 digit code you want and press enter.
Make sure the battery is good in the keypad.
Feb 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My keypad does not have a enter button and im trying 2 reset the password....what do i do??
I had the same problem and I found an old Liftmaster keypad instruction handbook. Check out the picture below and follow what it says. It worked for me!
P.S. Sorry if the picture is hard to see.
P.P.S. To change your 4-digit PIN:
Enter existing PIN, press *, enter new PIN and press *. To test and use, enter your new PIN and press the 0 key.
Jun 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
160 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
