Question about Toshiba TZ50V51 50" Rear Projection Television
Toshiba model# TZ55V61 chassis# TAC9952 need service manual
Can anyone help me find the service manual for this set. the tv flashes. Picture goes off then comes back , again and again... audio stays on. when in the menu tv doesn't flash.
  • 4 more comments
  • Anonymous Nov 19, 2008
    I have the same tv and would like access to a service manual
  • magicdragon Nov 19, 2008
    I have the same TV and am looking for a service manual as well. My problem is the TV doesn't come on anymore. Prior to failing altogether, I was having color convergence problems.
  • mcraze123 Dec 02, 2008
    I fixed it, it was in the system controls board, I replaced the board.
    "samswebsite" did not have the service manual
  • Anonymous Jan 26, 2009
    I have a Toshiba TV Model TZ55V61, Chassis no. TAC 9952, 54". The TV continues to turn off and a red light flashes. No should but a blinking red light. Also, the colors are off. Can someone direct me how to repair these two problems? I would like to know what parts I need to replace and where to purchase them. The TV repair store wants to charge me over 900.00 dollars for repair and for that much I could buy another TV. I like my TV and would like to repair myself.
  • cyriacus joseph May 11, 2010
    check " samswebsite"
    Sergeant:
    Champion:
  • 227 Answers
Let me see what i can do for you on monday, ok
Posted on Nov 16, 2008
My screen ripped i need to replace it where can i perchase one for my toshiba model # tz55v61
I own this TV and it no longer works. I am willing to sell the screen. Please contact me at ljtebbe@gmail.com
Feb 10, 2010 | Toshiba TZ55V61 55" Rear Projection...
Power light flashes - no picture - unplugging doesn't resolve it. Any had the power supply problem fixed? What is cost?
do you have sound??? do you tv is power on? if both of the question you say yes this will be a lamp problem
www.discounttvlamps.com
Dec 18, 2009 | Toshiba TZ55V61 55" Rear Projection...
Toshiba projection
You have a power supply or shutdown circuit problem.There is a manual called toshiba power supply and shutdown circuit troubleshooting available at the following link for 10.99 this book is invaluable for repairing those circuits. your model is coverd in that manual. here is the link, They will email it to you also.
http://servicemanuals.vstore.ca/
Feb 01, 2008 | Toshiba TZ55V61 55" Rear Projection...
Service Menu RCA HD56W58 56" TV
http://www.hdtvoice.com/voice/showthread.php?t=24248
go to http://www.thomsonnetwork.com
Click on "publications ordering" (in the list on the lefthand side of the homepage)
Click the box for service information. Enter the model number (or click the chassis button and enter the chassis number).
In the list of documents you can purchase for $40 ESIATC32X -- the service manual on CD for your set.
This disk will have the info you need.
If you do decide to purchase it (and I highly reccommend you do so), send me the alignment chapter and I would be happy to post it for others who have the same set on my homepage.
Jan 28, 2008 | RCA HD56W58 56" TV
Screen all green
Your set is definatly Toshiba 43A9UE has Chassis A9PJ the parts may be hard to find give Toshiba the Chassis number that should be waht they need. Hope this helps. If you need some part in paticular such as a Green CRT let me know I will try to locate one for you, just would need the tube type and number off the tag on the tube.
Jan 25, 2008 | Televison & Video
Toshiba tv-model tz55v61
If the red,green and blue mixture adjustment is what you want...
remove front lower speaker grill & access panel..locate RGB
adjust on Screen / focus block.......slightly adjust screen controls for best mixture....do not adjust focus controls.....T.
Jan 10, 2008 | Toshiba TZ55V61 55" Rear Projection...
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Bush RF6694D TV (Service Mode)
Hi.
I may be able to help you but I need to know the chassis number of your tv set.
This will be on the back of the set on the same label as the model number or if not there it will be on the main pcb.
It could start with AK, or PT.
http://dysonmanuals.inc.io/
Chris..
Dec 14, 2007 | Televison & Video
Tv won't power on
Pull chassis,check soldered in micro-fuses,F851,F852,etc.
2)Usually,convergence IC's need replacement,if shorted.Check
it out and let me know.......T.
Oct 23, 2007 | Toshiba TZ55V61 55" Rear Projection...
Power problem
1)all TV's I service get the chassis pulled for good visual inspection and soldering any/all suspect connections,esp. any
active device mounted to a heatsink.
2)Check horiz drive circuit for weak capacitor.
3)Let me know if you are still on it.....T.
Oct 24, 2006 | Toshiba TZ55V61 55" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
298 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
