Question about HP DeskJet 3940 InkJet Photo Printer
Out of paper
Printer ran out of paper, put more paper in and when i print status says out of paper. How do i fix this or can i reset the printer, looking for a awnser.
    Sergeant:
    Champion:
  • 200 Answers
Hi
Turn of the printer five minutes and then try it will work.
Thank you
Posted on Sep 16, 2008
    Scholar:
  • 148 Answers
Refill it but not necessarily with as much paper as it can possibly hold - many printers like a little elbow room in their paper trays. Make sure to feather the pages to eliminate static. Hold the pages in one had and flip through the pages at a fast rate with your thumb. If the paper tray is not empty, check for a misfeed. A sheet may have been caught in the mechanism. There may be a variety of printer access doors to check. Pull out any remnants. Even the smallest piece of paper could be causing the problem, so check carefully. Tweezers are handy for this procedure.
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 16, 2008
    1. Check the printer and/or the software to see if "manual
    feed" is selected. If manual feed is selected, the printer may be
    looking for paper in another tray.
    2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
    3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
Ran out of paper and when i put in more paper i can't get paper to feed and print. When we just bought printer there was not a manual
Try the steps below to fix the issue:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Aug 31, 2011 | Lexmark X5470 All-In-One InkJet Printer
Hi i ran out of paper while printing. ive put more paper but is telling me i need to so something else and when i go to print it still says out of paper. what do i need to press??
Press the "ok" or "enter" key on the printers keyboard to reset the printer. Then it will try again and recognize that it has paper in it.
May 18, 2011 | HP DeskJet F380 All-In-One Printer
Hplaser jet 1200 printer. without paper printer shows online and not printing anything
it is showing the status of the printer that it is online, you have to put paper in the paper tray so that it starts the printing.
Dec 31, 2010 | HP LaserJet 1200 Printer
Cannot empty the print que print jobs on IMac status is Deleted, except for last line which says "printing", but it is not printing
This is most likely because an error with the printer is making it impossible to delete the final print job. The most common error is no paper or a paper jam. Look for blinking lights on the printer and any error messages. Feed more paper if necessary. Once you fix the problem, reset the printer or press the blinking button.
Feb 21, 2010 | Dymo LabelWriter Thermal Printer
The light on the right is flashing red.
d40a83b.jpgCancel button
0de392d.jpgPrint cartridge status light
84e6616.jpgResume button and light
e1e1095.jpgPower button and light
- If the power light is flashing it means that your printer may be receiving data.
- If the resume light is flashing you may be out of paper, or you may have a paper jam, you may be printing a two sided document by hand and the first side has finished printing.
- If the print cartridge status light is flashing that means the top cover may be open, of there may be a problem with one of the cartridges.
- If all of the lights are flashing the printer may need to be reset.
Hope this helps.
Jan 06, 2010 | HP DeskJet 932c InkJet Printer
Printer has status light red as if a printer jam. Normally when you turn on you hear something spinning, but it seems to stop with a clunk?
please your printer is check a paper tray. and openyour head couver
and towner is out of printer and so the paper piceses is in fixing to the any other roller ? and put in towner and couver is close and printer is on and aply a paper put in paper tray and aply the printer self print to button is on.
Oct 07, 2009 | Samsung CLP 300 Laser Printer
Printer status column says printing AND yet no print comes out
Please uninstall and reinstall the software once and that will fix the issue....
Good Luck...............
Jun 05, 2009 | HP J4680 Office Jet All-In-One Printer
Canon Pixma iP1600 Printer problem
this is the service error download canon chip resetter utility, then reset your printer , download IP resetter utility
Nov 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Won't print
I'd guess that the machine is unable to pick up the paper so goes into jam mode, paper feed roller is worn, needs screwdrivers and parts.
Here is PARTS also needs little japanesse type fingers, gentleness, then a few bits come off from left side, spring, solenoid, and a couple of gears then tray out, 6 screws release base, few more bits and your done.
You should feed ok from bypass tray still and can have a dodgy attempt at fix by wiping paper feed roller(3cm rubber funny shaped roller sits front centre under with tray out) with something to clean it free of paper dust. ie metho, water.
Nov 03, 2007 | Brother HL 5140 Laser Printer
HP DeskJet 3940 InkJet Photo Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
