Question about Lexmark Office Equipment & Supplies
Have successfully installed my Lexmark X4650 wireless connection so that it works well, but when trying to scan an item to my computer is comes up with the message "unable to download application list". Can you help please? Thank you
    Scholar:
  • 148 Answers
CHECK IF YOU HAVE PROPERLY AND COMPLETELY INSTALL THE DRIVER PACK AND SOFTWARE.
Posted on Sep 16, 2008
I have a Lexmark X4650 InkJet Printer I need to find a driver to install
You can download the drivers for your Lexmark X4650 at www.Lexmark.com. Just choose the Operating System of your computer.
May 03, 2012 | Lexmark X4650 All-In-One InkJet Printer
I cant get my 4650 to scan it keeps saying downloading application list but it never does anything
If you are scanning documents to edit or save as PDF file, you will need to install the OCR scan software on your computer. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If scanning from your printer to your computer was working previously, then it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected) > reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to scan again once the computer fully recognizes the USB connection (if USB connected). If printer is connected wireless, wait until the WiFi light on the printer turns on solid green before trying to scan a document.
Dec 28, 2011 | Lexmark X4650 InkJet Printer
My lexmark x4650 wont print pdf files
Make sure that your printer driver is updated. Please visit the Lexmark website to download and install the Lexmark X4650 printer driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. After the installation process is successful, try to print your PDF file again to verify that the problem is fixed.
Also, make sure that your adobe acrobat reader is updated.
Nov 03, 2011 | Lexmark X4650 InkJet Printer
I want to set up a wireless printer connection, but I lost the installation CD.
Please visit the Lexmark website to download and install the Lexmark X4650 printer driver on your computer. Select your operating system > download > execute the file. Just follow the instructions on your computer screen.
Sep 19, 2011 | Lexmark X4650 InkJet Printer
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
I've lost my set up cd and although the printer and copyer work I cannot scan a document onto the computer.
Scanning a document to your computer may require the Lexmark OCR scan software which is only available in the installation disk. Try to contact Lexmark technical support to request for the installation disk. Thank you for choosing Lexmark.
Sep 15, 2010 | Lexmark X4650 InkJet Printer
I'm trying to scan a picture to my computer,but can't get it to work
The only way I got my Lexmark to scan, was to install the CD that came with it. It installs a program called "Lexmark Imaging Studio". That's where the scan will be transferred to from the printer.
To scan: Press the Scan Mode button, and then the check mark in the middle of the buttons. Then to activate the scan, press Start Color or Start Black to start the scan. With the Imaging Program installed, it will automatically come up and display the scan, where you can scan more or save or print the scan. I have the X4530 Lexmark all-in-one, but the program should be the same, or similar. Good luck, hope this helps.
Apr 18, 2010 | Lexmark X4650 InkJet Printer
Failure to install X4650
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 - The printer works correctly wired or wireless, but the scanner does not work properly - it cannot send data back to the computer by wire or wireless, only to memory card plugged directly...
Hi, Thanks for your posting in FixYa.
It assume to be incomplete installation for the Scanner drivers for your All-in-one Lexmark printer.
Is the data saving on memory card or not? May be the drivers are not updated or the Registration / Online Activation is incomplete.
Let me know if it helps or if you need further help. Dont forget to Rate the solution.
Regards
ELLIN
Sep 21, 2008 | Lexmark Office Equipment & Supplies
207 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
