Question about Astar Televison & Video
AStar Flat HDTV Monitor
Suddenly went off then smell like faulty wiring. When turned on again, nothing registers on the monitor.
  • 95 Answers
I think you may have answered the question yourself. I would say you'll need to get it repaired. Usually it's just the power converter at a cost of around 200-500 dollars.
Posted on Sep 17, 2008
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
My monitor went black, and the power switch just flashes.
is your CPU working properly? if that the case, your monitor is in need of a service.
reasons for why a monitor goes blank?
Reason 1: Wetness
The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card
The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM
This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections
Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard
And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
try this.
please rate my solution.
have a nice day.
Jul 05, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Gateway 19inch wide screen, lcd monitor stopped working randomly.
It could be a faulty power cord. Try plugging it in and moving the cord around in the areas where it takes the most movement. Do the same with the data cable to see if you get a response there. If your cables are fine, the problem is most likely hardware in the monitor - in that case you're better off replacing the monitor.
May 06, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
The screen on my monitor suddenly went white. i have nothing on the screen, no border, icons,etc. what could my problem be? can it be repaired?
Try connecting your monitor with another PC and check if the problem is with your Monitor or is it the Video Card of your PC which is not sending Video Signals to your Monitor.
Apr 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
My Gateway 19" FPD1960 TFT LCD Monitor suddenly went dead.
ooooooo yeah there is .. its corrupt eeprom memory . if you find the eeprom for the micro on the main bord short pin 5 to pin 1 then plug it in and wait a few seconds and remov whatever your shorting it with . thee monitor will use default data to turn on and it will rewrite the eeprom with new data. i added a pair of wires that hang out the side of mine to do that when it needs it . about every eight months.. but first before you take it apart see if it might turn on in the service mode by pressing and holding "menu" and "power" if that works you can select the option clear NVM . which would clear the non volitle memory eeprm..
Nov 29, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Yellow stripe in the middle....
Your TV having the main board defective. Any question please call me at 323-767-6030.
Sep 26, 2008 | Astar LTV-3201 32 in. LCD Television
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
The Right Half of My Screen Is Grayed Out
It seems unlikely that two pins would be missing. They would more likely be bent down. If there's no bent pins, it looks like it could be a faulty monitor. Certainly, when TFT displays go, they tend to manifest the fault in a colourless or multicoloured bar consistently across a portion of the screen.
Feb 04, 2008 | ViewSonic VA721 17" LCD Monitor
Astar flat screen monitor
i need help getting my astar flat screen tv to power on. the blue light is on in the center of the tv
Dec 24, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Televison & Video Logo
139 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
