Question about Dryers
Maytag dryer not blowing hot air (2yrs old)
Hi there, you repliedto my first question: is it plugged in; does it run are lights on. The dryer has operated just fine until we moved. When we moved 2 days ago the dryer was operating correctly, running and blowing hot air. By the fourth load the dryer was only blowing cool air. Still runs fine, operates well just no hot air. Could it be that the vent is plugged?
  • Anonymous Mar 20, 2014
    The dryer won't blow hot air
    Scholar:
  • 83 Answers
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Posted on Sep 17, 2008
Air will not come out the vent on my maytag dryer
Check the filter and give it a clean. That could be the problem as if there is no where for the air to go it can't come out.
Sep 28, 2014 | Maytag Dryers
My maytag front load dryer turns on and runs,it does not blow any hot air
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MY MAYTAG DRYER DOES NOT BLOW HOT AIR ANYMORE
Here is a tip and at the bottom of that one is another one for electric dryers...
They will help you with your problem...
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Mar 28, 2010 | Maytag PYE2300AY Electric Dryer
My maytag dryer does not turn on...The light is also off....what
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Sep 22, 2009 | Maytag PYE2300AY Electric Dryer
My maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Maytag Dryers
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
No hot air for dryer
this is most likeky thermostat you can find here http://www.partstap.com/
Feb 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
795 people viewed this question
Top Dryers Experts
