Question about Icom IC-R10 Handheld Scanner
Very low volume
I have the SQL turned all the way counter clockwise and the volume all the way up and still have very low, weak sound?
  • mluckham Dec 26, 2008
    Same here - volume with an earbud is fine, but the built-in speaker volume is pitifully low.
  • Anonymous Apr 09, 2009
    I have the same problem, and its not what mode its in.
  • 36 Answers
Have done more research on this, and made some tests. I found the Ext Speaker jack sometimes did not make good contact when the earphone plug was removed, and cleaned/lubed the jack ... the entire unit must be disassembled for this, as the jack is mounted on the third circuit board which is soldered to the antenna jack and a ground shield in several places.
Audio output to an external speaker, whether connected to the earphone jack or directly to the main speaker contacts, is the same. An unpowered external speaker (4-inch audio speaker was used) has quite satisfactory volume. The internal speaker audio works, but seems distorted - I'll try to find a replacement.
Posted on Dec 02, 2009
  • mluckham Dec 31, 2009
    I replaced the speaker with a new one from iCom - only $11 with a few dollars for shipping. Distortion is gone now - hard to tell whether the volume improved or not.
  • 120 Answers
Check the mode button and make sure you are in the right mode, sounds like you have it in the wrong mode.
Posted on Jan 10, 2009
Poulan te450 xl
Probably the metering diaphragm, or the low side of the carb needs adjusted counter clockwise in 1/4 turn increments.
Jul 10, 2014 | Poulan 17" T&E Gas Trimmer
How to turn the volume up on ipod nano2gb
Run your finger clockwise around the circle that has "Menu", "Fast Forward", "Rewind", and "Pause". Clockwise increases the volume and counter clockwise decreases the volume.
Jun 29, 2014 | Apple iPod nano
Static noise will not go off unless I hit talk button but when I let go it comes back on
The Squelch control is turned too far down. The control should be labeled "Squelch" or "SQL" Turn this control clockwise until the white noise stops. You may want to turn it very slightly further, but not too much.
This control sets the sensitivity of the radio, if too far counter clockwise it will receive noise. If too far the other way it will only receiver very strong signals.
Apr 08, 2012 | Motorola Talkabout FR50 (14 Channels)...
I need to know what knobs turn which way and what buttons need to be on
Volume/Squelch control: As desired
ETone: Sets the sound of the echo as desired
MicGain/RF Gain control: Normally, leave fully clockwise
Band Switch: for CB, turn all way to left (a/e)
Mode Switch: Selects how you modulate the radio. Normally, you will operate on AM, USB or LSB.
Fine/Coarse control: Changes the frequency you operate on. Normally, set so the frequency counter reading ends in 5. (center slot of the channel).
RB: Roger beep. Turn on or off as desired.
NB/ANL: Noise limiters. Leave on.
Frequency Counter: Turns counter lights on and off.
+10 KHZ: Allows you to get the channels missed by the Channel knob. Normally, leave off.
Power: Selects either high or low transmitter power setting.
Band: Selects band of operation. Low (A-D) or High (E-F)
Jun 12, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Got a "Dwell" effect when
It sounds like you have cable in the wrong ports. Make sure your cabling goes in to out on all ports. Also make sure no cable are bent or heavy equipment on top of it. If your getting sound but sounds like muted sound its either cable in the wrong place bad cable or amp setting is to low.
May 04, 2011 | TC Electronic Classic Sustain & Parametric...
Volume on tv adjusts automaticly
is the volume of your tv adjust automatic with a volume indicator on the screen appear?if that the case clean the volume controls on the mainboard with a contact cleaner..2nd is is the volume adjust with no volume indicator on the screen?your problem might be onthe sound if section.adjust the sound IF with a plastic screwdriver clockwise or counter clockwise until the soun stabilises..adjust the IF with a power is on.
May 17, 2010 | Televison & Video
Need to know low and high air screw adjustments
Turn both of them in all the way then back them out one turn. This should let you start it. Then turn the high air screw clockwise until it begins to stall, then turn it counter-clockwise until it begins to stall. Then turn it somewhere in between the two where it sounds smooth. Same with the low.
Apr 28, 2010 | Homelite Mighty Lite Lawn Trimmer
Where is the volume control on LG KU990?
its the camera ring thingy outside the lens on the back of your phone, you can turn counter clockwise to increase the volume (might be the other way I'm not sure)
Aug 10, 2009 | LG KU990 Viewty
Volume dial decreases volume if turned either way
i took my head unit face apart and got the volume control off, sprayed a little WD40 and it worked like a beauty!
Jun 03, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Icom IC-R10 Handheld Scanner Logo
344 people viewed this question
Top Icom Radio Communications Experts
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
