Question about Garmin GPS
With either car having the garmin plugged in, it still does not work
  • izmir69 Sep 16, 2008
    it does not power up at all - it did apparently a week ago
  • izmir69 Sep 18, 2008
    thank you for your help. It was a bad fuse and now it works perfectly. Many thanks!
    Scholar:
  • 147 Answers
By doesn't work, do you mean it doesn't show any signs of power, or do you mean it won't get a fix?
Fresh out of the box, (or if it was last powered up in another country) you may need to let the antenna sit outside the vehicle, with a good view of the sky - like a mall parking lot - for up to 12 minutes or more. If there is an option to turn the antenna on or off (demo mode for in-store display), you'll want to make sure your antenna is enabled.
Posted on Sep 16, 2008
  • David Friesen
    David Friesen Sep 16, 2008
    Have you tried using it standalone, with known good batteries or a wall adapter? Is it only when using the car adapter that it won't power up?
    If so, the car adapter might have a fuse in it. The Garmin PC18 has a fuse inside the cigarette adapter, which can be removed by unscrewing the plastic ring around the center pin.
Garmin says low battery and now will not work in the car. Does this Garmin have a battery inside the unit that I have to replace?
There is a battery in the satnav but it's not user replaceable. It can only be replaced by returning it to Garmin. Before sending it away to replace the battery you could check the following;
  • Have you the satnav connected to the charger?
  • If it's connected to the charger is the cigarette lighter socket working. You can check by plugging in another device to see if it works
  • If the cigarette lighter socket is working and the battery of the satnav is not charging it's possible that the fuse in the plug, that goes into the cigarette lighter socket, is blown.
To change the fuse;
Unscrew the ring that's at the end of the plug and the plug comes apart. Be careful not to lose the silver coloured tip. When the plug comes apart you can take out the fuse and get a replacement at any car accessory shop or a shop that sells garmin satnavs.
If you have to return your satnav to garmin you can find their contact details at http://www.garmin.com/garmin/cms/home/support/supportcontact
May 23, 2011 | Garmin nuvi 255W GPS Receiver
Hello. I have a Garmin Nuvi level 200. The car charger was damaged so I have purchased two at two separate stores. Neither works. When you plug it into the car charger, an icon showing "garmin connected...
The problem is not the power lead. It's the socket on the back of the satnav. Due to wear when you plug in the mini usb plug it feels as if it's fully in but it's not. Push it in further and it'll work ok.
Aug 11, 2010 | Garmin nuvi 1200 Car GPS Receiver
My garmin nuvi 2255w is completely dead. Will not turn on, the screen stays blank. I plugged it into the car plugin and it does nothing. It was working just fine before now.What could be the problem?
My garmin Nuvi (205 I think) just stopped working...blank screen, does nothing? Was working fine a few hours ago. Car plug in lights up when plugged in but still nothing.
Feb 08, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 260 does not work when plugged in
I assume you mean when you are trying to plug in to your car?
Have you changed car plug lately?
You have to use a Garmin approved car adapter.
Jan 30, 2010 | Garmin nuvi 260W GPS Receiver
When i plug in my Garmin 250 in the car it will not function until i unplug it everything else works great but will not work when plugged in the car
Do you have a factory Garmin cord?
Do you have voltage at the plug in the car?
Is the cord you are using good?
Does the cord you are using have a fuse in it?
Is it good?
Sounds like you are not getting power to the unit when plugged in.
Check all above.
and.......try another cord....try plugging into another cars plug.
Sep 24, 2009 | Garmin nuvi 250 GPS Receiver
Garmin sat nav not working
Do you have screen with cable plugged in a computer? is yes then your charger (power) is not connected to Garmin properly or lose.
If your answer is NO than check your charger may be it's not working.
Apr 30, 2009 | Garmin nuvi 255W GPS Receiver
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Can my Garmin 610T be used whilst charged in the car
Fully charge the device before using it...did you plug any sd cards into it?
Jul 03, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi
return the GPS to Garmin. there is one year mfg warrinty
Mar 22, 2008 | GPS
GPS Logo
43 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
