Question about Acer TravelMate 2300 Notebook
I can not access my wireless - Acer TravelMate 2300 Notebook
  • 40 Answers
Duh,
Can you access with wire connect direct to the router?
Posted on Sep 16, 2008
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
Tip
Wireless Access Point Placement
Place your <b>wireless access point</b> in the average of you location. Almost all <b>wireless access points</b> appear with omni-directional antennas, which afford a doughnut arrangement signal in all directions. If you abode your <b>wireless access points</b> abreast a bank again bisected of your signal is activity out the door.
on Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
Problem with the Cisco Aironet 1242AG Wireless Access Point , very low signal strength
Please ensure that:
1.The wireless access point is not in close proximity to a source of interference,e.g a microwave transmitter or microwave oven. 2.Ensure that it's not placed in an area prone to physical obstruction, e.g behind a high wall or where people pass through(because our bodies have water which absorbs such waves!).In that case, re-position the wireless access point to another area, e.g a roof top. 3. If the wireless access point is in vicinity of other wireless access point, ensure that CSMA (Collision Sense Multiple Avoidance) scheme is enabled for the device.
I hope these solutions solve your problem. Have a great time ahead.
Feb 03, 2011 | Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9)...
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
I am havi a prob stopping people from bouncing off my internet i have a linksys wireless router how do i make it so you cnt access my web
To secure your wireless network from unauthorized access, you need to setup wireless encryption and limit wireless access. Please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Aug 19, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I want to know how to connect wireless
In order to connect to wireless, 1st u need to have a devices with wireless features, such as laptop.
When switching on your wireless, it will able to detect the wireless access point available. For non secured wireless, u can access the wireless network. If secured wireless, passkey is needed to access.
Apr 06, 2009 | Computers & Internet
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Belikin adapters and a wireless gateway
If your router is not wireless capable you need to add "wireless access point" on your network so that your wireless computers will be able to connect wirelessly to your network. You can buy WAP54G of Linksys or other brand of WAP(wireless access point).
Jul 08, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Installing a Linksys Access Point to a Verizon Actiontek wireless router.
The IP Address of WAP54G is 192.168.1.245
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : 192.168.1.10 , the subnet mask should be 255.255.255.0
Open the setup page of the Access point, by typing 192.168.1.245 in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
Mar 28, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Computers & Internet Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
